stuck clutch
/ stuck clutch #1
gary65cars
the clutch on both my 102 and 108 are stuck. You can't stop them without the kill switch.Is it internal or can i do something without tearing it apart?
/ stuck clutch #2
Not sure what a 102 or 108 is.
Assuming some sort of tractor, one thing to try would be mashing the brakes hard and trying to break the plates free.
On my dozer I used the brakes to break the steering clutches free after sitting for some time. Forward and back, forward and back.
Joel
/ stuck clutch #3
G'day i have got them unstuck by driving around with my foot on the clutch and on and off the throttle, hope this works for you otherwise it's time to open her up:)
Jon
/ stuck clutch #4
If you have a plow or box blade the would help put more stress on the clutch and maybe free it up. Just remember to keep the clutch pedal depressed.
/ stuck clutch #5
Put it in the highest gear, block the clutch peddle down or have someone sit and hold it down and rock it back and forth with the rear tire. Not running of course.
/ stuck clutch #6
This is a commonly discussed issue. Search under "stuck clutch" and you'll get all kinds of good advice. Based on what I've read you should be able to unstick your clutch without going internally.
Good luck, and be sure to post what works for you.
/ stuck clutch #7
had it happen one time: had to break the tractor in two in order to get it unstuck: hope you have better luck.
heehaw
/ stuck clutch #8
Any chance it sat for while? Just a guess. Another suggestion that's worked for me:
Attach something to the PTO takes some energy to get started (a brushhog, chipper, etc). Then engage the PTO while holding down the clutch. If it doesn't break free then quickly accelerate the throttle while still holding down the clutch.
2011 CARGO CRAFT ENCLOSED GOOSENECK (A67714)
2011 CARGO CRAFT...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft. Insulated Bucket Truck (A66736)
2012 Freightliner...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2024 CATERPILLAR 239D3 SKID STEER (A65056)
2024 CATERPILLAR...
