stripped out tranny drain
   / stripped out tranny drain #1
mya
b2410 kubota
I have a striped out transmission drain hole where plug goes on my B2410 best fix? any help or suggestions much appreciated
yeah was not really wanting to drill into trans drain hole,iam familiar with helicoil but whats a timesert?
thats the problem its not a pan its the housing of the tranny that the axel comes thru
   / stripped out tranny drain #6
I always try to use a heli-coil as it means the smallest hole enlargement. Use grease on the drill and tap to catch any chips and blow low pressure air into the fill hole to blow chips out. Is the case aluminum or iron? If iron, you can also use a magnet. Be sure to correctly measure the case thickness so you get the heli-coil length slightly shorter. Careful on breaking off the end tab so you don't lose it inside.
   / stripped out tranny drain #7
Like ruffdog said grease on tap and drill then flush it with trans fluid a few times.
  • Good Post
Reactions: mya
   / stripped out tranny drain #8
I have an aluminum case that I bought a Heli Coil kit for after reading up on various repair methods. The drain bolt is currently snug enough, but stripped. I'll be making the repair next spring.
Anyway, you mention breaking off the tab, and not dropping it inside. Is there a best practice way to do this? My plan was to not use the included punch and try breaking the tab off with a pair of needle nose pliers.
Any advice appreciated.
   / stripped out tranny drain #9
Like was mentioned above you could use a time-sert. No tabs to bust off with those. Not quite the thread strength of a helicoil but it going into aluminum on a tractor not a m1 Abrams tank. And they were the TSB repair for the Northstar stripped head bolts. Good enough for a Cadillac head should work for you.
   / stripped out tranny drain #10
Yes, a nice pair of needle nose pliers that have some room to twist back and forth. Grab the tab, wiggle, remove.
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
Genie GTH-644 (A50490)
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
