stripped out tranny drain
/ stripped out tranny drain #1
mya
b2410 kubota
I have a striped out transmission drain hole where plug goes on my B2410 best fix? any help or suggestions much appreciated
yeah was not really wanting to drill into trans drain hole,iam familiar with helicoil but whats a timesert?
thats the problem its not a pan its the housing of the tranny that the axel comes thru
/ stripped out tranny drain #6
I always try to use a heli-coil as it means the smallest hole enlargement. Use grease on the drill and tap to catch any chips and blow low pressure air into the fill hole to blow chips out. Is the case aluminum or iron? If iron, you can also use a magnet. Be sure to correctly measure the case thickness so you get the heli-coil length slightly shorter. Careful on breaking off the end tab so you don't lose it inside.
/ stripped out tranny drain #7
Like ruffdog said grease on tap and drill then flush it with trans fluid a few times.
  • Good Post
Reactions: mya
/ stripped out tranny drain #8
I have an aluminum case that I bought a Heli Coil kit for after reading up on various repair methods. The drain bolt is currently snug enough, but stripped. I'll be making the repair next spring.
Anyway, you mention breaking off the tab, and not dropping it inside. Is there a best practice way to do this? My plan was to not use the included punch and try breaking the tab off with a pair of needle nose pliers.
Any advice appreciated.
/ stripped out tranny drain #9
Like was mentioned above you could use a time-sert. No tabs to bust off with those. Not quite the thread strength of a helicoil but it going into aluminum on a tractor not a m1 Abrams tank. And they were the TSB repair for the Northstar stripped head bolts. Good enough for a Cadillac head should work for you.
/ stripped out tranny drain #10
Yes, a nice pair of needle nose pliers that have some room to twist back and forth. Grab the tab, wiggle, remove.
/ stripped out tranny drain #11
With any insert it helps tremendously if the drilling and tapping is as straight as possible.
/ stripped out tranny drain #13
/ stripped out tranny drain #14
There are tangless Heli-Coils available. More than one manufacturer of them. They require a special insertion tool. I have never used them so can't give any advice on how to make your own insertion tool. They use the same drill and tap as the standard tanged insert. FYI, sometimes the stripped out hole is large enough to be just tapped, not drilled and tapped. The usual way to find out if you don't have measuring tools is to just try tapping, carefully. Anyway, a web search for tangless thread inserts will result in many hits.
Eric
2013 International WorkStar 7400 Altec AM547 50ft Material Handling Bucket Truck (A61568)
2013 International...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2020 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2020 Globe Trailer...
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
