~~~ STRING TRIMMER PROBLEM ~ ~ ~
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Stihl FS 46 won't start won't even hit a lick. It's a 2001 I bought new 9 years ago.
Never had a lick of trouble with it till now.
The following has been done so far,but still no go.
New clean fuel .
Carb cleaned & new diaphragm installed.
Any one have any other suggestions ideas tips.
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #2
Is it getting a spark?
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #3
He took my answer..
BUT is the plug spark weak? is the plug 9 years old? :)
J
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #5
how is the compression?
here is a don't do this at home trick: :(
Take the plug out, set a lit propane torch behind the plug hole and pull the rope several times..
nah-- that sounds like one of those hey yall watch this videos....
do you have one of these:
AutoZone.com | In line ignition spark tester | In line ignition spark tester
I have a similiar one for my toolbox for small engines.. But it is not quite the same..
a couple of times when working on push mowers I have seen the flywheel key that had skewed slightly not get a strong spark. anyway, I could see a spark on the plug but it was weak on this type gadget...
pulled the flywheel off and sanded the magnets, replaced the key and walla!
anyway, is it electronic ignition?
J
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #6
LBrown-- in addition to the previous posts (spark? fuel?), you might take a look at the crankshaft seals, especially the lower one.
I'm guessing that's a 2-stroke engine; if the seals are worn/leaking, it'll never "suck" enough to pull fuel/air in during the upstroke of the piston, even if the compression is fine.... A good test for this is a QUICK shot of starting fluid at the intake point. If it fires right up, that may be the problem- it's pretty common on 2-strokers that have some age.
WBB in NH
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #8
Shoulda bought a Deere.
with a loaded spool... wait does a heavier spool cut better?
and what do you use to load it with ? beet juice or ???
it has truly been a long day.......
J
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #9
Don't mean to harp on something that you have probably already addressed, but did you actually see spark? New plug does not necessarily mean you have spark (could have a bad coil). Let us know.
-Jay
   / ~~~ STRING TRIMMER PROBLEM ~ ~ ~ #10
Yes you need to know there is a spark getting to the plug. If there and pin holes in any of the fuel lines pump bulb you will not get fuel to the carb. Also check the exhaust ports to see if they are stopped up..
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2018 John Deere 1653 (A55302)
2018 John Deere...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
