Stream Crossings
   / Stream Crossings #11
Use your back or box blade to tow with,
chain of the blade with the ability to use the blade as a stop for what you are towing.
   / Stream Crossings #12
You've also got lots of trees on the way to the creek, so you could also winch the trailer bed down to the creek using the trees as anchor points. - with a pulley, you could also use the tractor as an offset puller to replace the winch.
   / Stream Crossings
Getting it across the stream would be a problem. Would need a winch with wire up over a high up pulley on the other side of the creek.
I used a little aluminum ramp made for ATVs as a cover over a culvert inlet to under my road years ago. Just made some tiers out of coffee cans filled with concrete to sit it on. Still there.
Ralph
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
2007 Ford Taurus SEL Sedan (A48082)
2007 Ford Taurus...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
2010 Toyota RAV4 Limited SUV (A48082)
2010 Toyota RAV4...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
