straight rows, how to
/ straight rows, how to #11
I suppose that if you wanted a new toy and wanted to spend big $$$$$$ you could get the New Enhanced John Deere Parallel Tracking System./w3tcompact/icons/smile.gif
<A target="_blank" HREF=http://www.deere.com/deerecom/_newsroom/021302_parallel.htm>http://www.deere.com/deerecom/_newsroom/021302_parallel.htm</A>
/ straight rows, how to #12
qzbmpc,
I have used the same type of arrangement as rsthom for several years. The only difference is that I use PVC pipe. It works great. The only thing to chance is getting the first row straight. To do that I just pick out a marker at the end and drive to it on the first pass.
/ straight rows, how to #13
You'll need a marker on both sides of the tractor for going back and forth. I'd make the rows 9 or 10 feet apart; after 5-6 years I 've had trouble getting a 5 foot mower down a 7' row. 7 foot rows are for Xmas trees that get shorn then harvested. As stated that first row is real important to get straight. However, I've taken to doing herringbone patterns so that it doesn't look so artificial. I've also done gently curving rows; just make sure that the slit comes together nicely with no overlapping or the trees won't make it through a dry spell.
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=44160&Search=true&Forum=All_Forums&Words=Rch&Match=Username&Searchpage=6&Limit=25&Old=allposts&Main=44160>Tree planter thread</A>
I'd make the marker out of metal- they seem to hit things and get bent up. Mine has electrical conduit that telescope into itself so you can collapse one side and snuggle up to a fenceline plus I can bend them back straight. That square tubing may not be as forgiving when you hit something and PVC will shatter.
/ straight rows, how to #14
I assume that everyone is aware of the federal and state programs that offer cost-share assistance on forestation/reforestation expenses (subject to qualification).
I had about 10 acres of loblolly pines machine planted (former pasture land) in Feb. 2001. The total cost was just shy of $100/acre and my cost was about $60/acre. I had another 10 acres hand planted (cut-over timber land) this Feb. The per acre cost is supposed to be lower for hand planting because no herbicides were used.
The tax rules get a little tricky regarding the treatment of the cost-share assistance. See http://www.timbertax.org/extras/developments/tax_tips.pdf
/ straight rows, how to #15
I am trying to do the opposite. Can I get federal assistance too. /w3tcompact/icons/smile.gif
My property hasn't been actively farmed in 50 years and has returned to forest. I've hired a forester to do a forest management plan (state of Maine reimbuses 50% of the cost) and then manage a timber harvest. I need pasture for the horses and an orchard (apples and blueberries) for me. The skidder will cut some nice horse trails for me at no extra cost.
/ straight rows, how to #16
I've heard horror stories here in Michigan of landowners allowing the state to plant trees or stock fish and then learning later that part of the deal is having to let the taxpayers hunt and fish your property. Maybe it was just coffee shop rhetoric, but I heard it more than once.
/ straight rows, how to #17
Interesting.
In North Carolina, the county ranger prepared a forest management plan for my farm at no cost to me. However, I pay all of the fees when I use a consulting forester to arrange and manage timber sales.
/ straight rows, how to #18
rdln, I also have heard that. I avoided such programs because of many restrictions including not being able to sell trees( except routine thinning) till certain size or the land itself for various periods of time. It seemed like a morass of regulation !
I know they have equipment to help you plant but try and schedule that sort of thing months in advance when you have a day job is fraught with glitches. I have access to a drive-in cooler at a cheese factory for storage of the trees if the weather is uncooperative. I've had as much as $2000 worth of trees over 1 to 3 weeks waiting for the ground to firm up. A Honey-Baked Ham every Xmas is good insurance ! Having your own equipment really helps work around the weather and the cheese factory is open 24/7.
/ straight rows, how to #19
Consider the laser mounted at the row end. Put a translucent laser target on the tractor front with a vertical target line on it. Steer so the laser dot is on the target line.
The diadvantage is setting up the laser for each row.
/ straight rows, how to #20
I still think a string. Lots cheaper and a couple stakes. Or use lots of stakes and lots of strings to lay off your garden then follow the lines. Let's see for $50 you can get enough stakes and strings to feed a small nation.
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
2016 FORD TRANSIT CONNECT SERVICE VAN (A59823)
2016 FORD TRANSIT...
60'' Skid steer bucket (A61567)
60'' Skid steer...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
72'' Fork Extension (A61567)
72'' Fork...
John Deere 4600 (A53317)
John Deere 4600...
