Storing implements for the winter.
   / Storing implements for the winter. #11
I just sprayed Fluid Film on the surfaces the paint has worn off of, and did a fresh grease job, and went around trying to tighten the wheel bolts (I was probably only applying around 50-70 foot pounds and didn't bother using a torque wrench, but would have brought the torque wrench out to check them all if I felt any of them shift). I washed the machine, too. I think of this as my winterizing, though my machine lives in a barn, and I use it in winter for snow.
I still have to put my urethane edge on the bucket, but am waiting until snow is closer to do that small job. I still may need to move some dirt first.
   / Storing implements for the winter. #12
Everything gets put into the tractor house except for the rear blade and front bucket. BH, mower, PHD, and box blade are inside, and the tractor....
   / Storing implements for the winter. #13
Tractor goes into the barn. Implements are under a steel carport.
   / Storing implements for the winter. #14
Here's where my cutter lives year around when not in use. Shaft is removed and stored on top of the cutter.
   / Storing implements for the winter. #15
Tractor is in the shed as well as flail and tiller. Forks, brush hog, carryall outdoors, sitting on timbers off the ground. Chipper absolutely stays in the shed when not in use.
   / Storing implements for the winter. #16
Tractor, bush hog, and backhoe attachment are stored inside. Box blade, carry all, and pallet forks are stored outside on pallets, uncovered.
   / Storing implements for the winter. #17
Everything that won't fit in the garages go onto to pallets and tarped.
Piece of treated wood to keep tarps from touching implements.
Some oil and grease as needed before covering.
   / Storing implements for the winter. #18
Power wash all equipment to be stored. Lubricate all zerk fittings. Sharpen any blades. Remove all dirt and debris under Bush Hogs, Buckets etc.
Drain All gasoline and run engine dry. Drain Float Bowl. Remove battery cables and clean the terminals. Charge Batteries fully.
Mesh bags of Mothballs will deter mice from wiring on small equipment. Shove small mesh chickenwire in access holes. Change Oil, oil filter and Air Filter if applicable. Air up all tires and block frames so if a tire goes down over Winter it is not ruined. Spray paint rusted areas. I spray used oil on the underside of mower decks and rototiller tines.
   / Storing implements for the winter. #19
Attachment in shed off the ground clean and lube soon to start their hibernation.
   / Storing implements for the winter. #20
I gotta say I never thought to remove the PTO shaft and bring it inside...
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
2019 Chevrolet Silverado High Country (A56436)
2019 Chevrolet...
INOP/NON-RUNNING 1997 Land Rover Discovery Multipurpose Vehicle (MPV), VIN # SALJY124XVA557589 (A57453)
INOP/NON-RUNNING...
New/Unused 5ft Quick Attach Mixer (A57454)
New/Unused 5ft...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
