Storage room for documents
/ Storage room for documents
I like the idea of electronic storage much better than building a room and maintaining it. I'll see if I can get her interested. Thanks for the ideas.
/ Storage room for documents #12
I have no idea what it costs, but there are companies who specialize in document storage. Iron Mountain is one that is big around here. Companies also use them for off-site storage of computer backup and disaster recovery tapes/disks.
One thing about document scan & store software to compare; be aware that some use a proprietary file format that only their software can read. The long-term viability of, and your satisfaction with, the software provider becomes something you also have to consider.
Dave.
/ Storage room for documents #13
Get a small shipping container and vacuum bag the documents. :thumbsup:
/ Storage room for documents #14
Write once DVD (DVD-R; DVD+R) media is pretty stable - good for at least 10 years if kept away from heat & sunlight. Archival versions claim stability of 100+ years if properly maintained. It is cheap to buy, making multiple (or periodic) copies an affordable option, and doesn't have the mechanical failure potential you find with a hard drive. The enemies of optical storage are typically heat and UV. Also, you should avoid add on paper lables, they have the potential to jam some readers as well as the ability to pull/tear the backside reflective layer. Inkjet printable discs are less prone to damage from felt tip labeling (from grit in the nib) than bare discs as well as giving a more legible result.
Retrieval software availability for archived data is a real concern. If you maintain actual document images in a universally readable format (.jpg, .png, .tif, image based .pdf, etc.), as well as any proprietary file formats being generated, you don't have to worry so much about being able to get at the data at a later time when the current software or operating system may not be available.
Nick
/ Storage room for documents #15
Transfer the documents onto clay tablets.
They do have a proven track record!:thumbsup:
/ Storage room for documents #16
Well, I just blew coffee on my laptop...thanks Egon!
1660 (A59213)
1660 (A59213)
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61307)
2023 Takeuchi TL6R...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
