Storage of Attachments.
   / Storage of Attachments. #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I'm in a suburban lot, with a 12x12 shed. I have enough attachments that I keep a cheap 12x12 storage unit with seasonal attachments, and make the swap twice a year.
I got my system down, uhaul 6x12 with a ramps, everything is on skates.
The only issue is my front mounted snowblower. It's a Deere 47 inch. I can't get it off and on the trailer easily. The skate I made has small wheels to unhook from the Machine, and it a bear.
Any ideas?
   / Storage of Attachments. #3
Lay plywood or planks on the ramps to create a smooth surface so the wheels can roll freely?
The larger wheels are tough. My quick hitch can't pick it up for larger wheels. Maybe strap it to plywood.
   / Storage of Attachments. #6
Could you use an engine hoist?
   / Storage of Attachments. #8
   / Storage of Attachments. #9
Maybe this system will help. I have several attachments and limited, covered storage. All my attachments with no moving parts are out in the orchard. Each one sits on its own pallet. My Wally chipper and my Land Pride grapple are in carport stalls - under cover.
These attachments - on their own pallets - are never covered. The worse thing that can happen is the paint will fade. Covering simply provides a place for rodents and larger beasties.
My grapple is always on the FEL and along with the tractor - the whole shebang sits in a large carport stall. The HD Rhino rear blade is always on the 3-point. Unless I'm using the chipper. I've had to struggle thru knee deep snow but I always know the tractor is snow-free and ready to go.
My tractor ALWAYS has something on the FEL and 3-point. Times have been, it just tough enough getting out to my tractor - thru the snow. Man - I do not need the hassle of installing the rear blade when the snow is knee deep.
Several years ago a large pine tree fell directly across my driveway. Fortunately - it did not take out the power line - which runs right down my mile long driveway.
With the grapple on the tractor and my chain saw I cleared this tree right pronto. The snow was about two feet deep. Clearing the fallen pine had priority. At over 10K pounds - the M6040 easily pushes thru two feet of snow.
   / Storage of Attachments. #10
My dad's Kubota BX had trouble hooking up to a PTO tiller that we stored on a dolly because of the added height so we make some 2x10 ramps to back the tractor on while hooking up, only took a couple extra inches. So my suggestion is to swap the dolly wheels for bigger ones and drive your tractor onto some type of ramp when hooking up your blower.
   / Storage of Attachments. #11
That's what I did with my jd 2305 years ago.
Drive all 4 wheels up onto a couple of 4'x4' pallets.
Or what ever is near the height of your dolly.
   / Storage of Attachments. #12
All my attachments are Cat 2. This means heavy. They are all 800 + pounds. Not the kind of implement that you can give a hip thrust to, to make 3-point connection.
Plus - as they sit out there in the orchard on their pallet - the pallets tend to settle into the soft ground. I've used - HI-Lift jack, hydraulic jack, big pry bar and finally - dibble. Just to get that final inch.
   / Storage of Attachments. #13
Get a set of pallet forks for the 3 PT on your JD 730 - it has a 3PT correct? Then put the snowblower on a pallet or a pallet with larger 6" dolly wheels. You can also store your other stuff on pallets too - makes it easier to move.
I am in the thinking stage of a storage rack to store 2 FEL buckets, the pallet forks and grapple in a 3'x7'x7' high rack with a lean to roof outside so they dont take up barn space.
Guys lots of good ideas! Thanks all.
I ended up using my vehicle oil change ramps to get the snowblower high enough to get onto an oversized dolly. I think I am also going to get myself a set of pallet forks for the three point too.
RoGator RG1100C (A61307)
RoGator RG1100C...
2020 Deere 544L (A60462)
2020 Deere 544L...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
JOHN DEERE 8200 18 ROW GRAIN DRILL (A60430)
JOHN DEERE 8200 18...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2014 JCB 930 (A53317)
