Stone/rock buckets
/ Stone/rock buckets #1
DMF
Platinum Member
Mass
Massey Ferguson 1552 Cab Model
I was wondering if anyone here uses or has used rock buckets in the past? I have an 80 x 100 foot pumpkin patch to get ready and I threw my back out last weekend. I picked tons of stones last year but plowing just pulled a bunch more out. I am wondering how effective they are; I know they are pricey. I also have many acres of field I want to reclaim so if they do work well, they will see lots of use. Thanks in advance for the input!
/ Stone/rock buckets #2
Rock buckets? Do they also remove the rocks under the ground? Cheapest (good, effective) rock picker (see attached example - >10 ft) I know of will cost more than $10K. But, such equipments are for use once only. If you rent it to make money, it is worth to buy a rock picker. In old days, my hand had picked rocks of trucks. I now think it was a good sport.
/ Stone/rock buckets #3
Nomad, a rock bucket is a front end loader bucket made from tines spaced so rocks stay and the soil falls through.
Slower than a true rock picker but closer to 1500$.
/ Stone/rock buckets #4
I bought a pull behind rock picker from a junk yard & am fixing it up /forums/images/graemlins/cool.gif
Also have a rock bucket on loader - works great on larger rocks 500-3000 lbs. Overkill on little stuff tines are 3" on center so if the soil is wet does not fall through or shake off /forums/images/graemlins/blush.gif
www.midsotamfg.com
2013 FORD F250 (A60460)
2013 FORD F250...
Domar Land Plane CA120 (A64047)
Domar Land Plane...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2007 STERLING LT9500 (INOPERABLE) (A63569)
2007 STERLING...
Stone CP13 Asphalt Roller (A64047)
Stone CP13 Asphalt...
