Stone dust for traction on ice
   / Stone dust for traction on ice #21
I'm getting different opinions on adding salt. Some people say salt increase moisture.. wondering what is true
On thick ice, salt is pretty useless. Works better on rain frozen to roads in light layers or thinly packed snow.
Once the layer of ice or snow is like 2”, you’re probably better off creating a new traction layer on top of the thicker ice.
You’d have to used tons of salt to melt thick ice-especially when it’s very cold.
I use pit run sand, I get a triaxle load every couple of years, it has some salt mixed into it to slow down the freezing in the pile.
This year when I got my load I added 500 pounds of more salt to the top and mixed it in a bit.
I also use coal ash most years to as a good way to use the ash.
The last 3-4 sacks of salt spread out
mixed into the top layer and all pushed back
Tarped and ready to be uncovered and loaded into the sander.
sander ready to be loaded and spread
That looks like what I want to do. Thanks!
I was talking about adding salt to pile of sand. Woudn"t it increase the moisture content and make frozen lumps?
   / Stone dust for traction on ice #24
Check your highway department, mine makes a 20/80 salt/sand mix available to the public. I keep a few 5 gallon buckets on hand, when I need more I stop at the town barn. The sand shed is open 24x7. They also keep a pile of 100% rock salt, but I avoid because we have dogs. All the town and village highway departments up here have a pile open to the public.
   / Stone dust for traction on ice #25
If you keep it covered/dry, no issues. If the pile is in the open, it will be frozen solid where I live.
   / Stone dust for traction on ice #26
It could. Especially if the sand pile was already damp or frozen. I stopped with the piles and the tarps cause I could never keep dry and went with storing indoors in 100lb bags. I think upon guys up in the “Great White North” type locations are probably going through 5-10 times as much as me, though.
   / Stone dust for traction on ice #27
This winter is like never before... Temp mostly above freezing and snow melts and becoming ice on my sloping gravel driveway. I got an idea to put stone dust on ice for traction. In the spring i just rake it into existing gravel. Will it work? Than it's a storage question. Thinking about 5-6 yards to store outside with no salt. How?
Any recommendations? Thanks
I recommend chains on your tractor's wheels. They will convert your tractor into a mini bulldozer! (y)
   / Stone dust for traction on ice #29
One year I used pellet stove ash. It worked great. Until I put it on the walkway - leading into the house.
Watch out what you use and where you put it. That pellet stove ash tracked terribly.
   / Stone dust for traction on ice #30
I got chains. On solid ice up the hill they are no help
Sorry to say, the wrong chains then.
These will bit and go, the best of any chains I used in a great many years.
I can stop and backup on my 26% slope on ice.
Yes, to other questions salted sand does tend to hold more moisture.
But the salt helps minimize the freezing. At times I'll have 4-6 inches of frozen sand in my pile,
I can push in under it and break up most of it and the sand under is still thawed.
I keep it cover as best as a tarp will do, to reduce the snow and rain that gets to it.
I'll drive over the frozen chunks then they will go through my sander.
2014 Jeep Patriot SUV (A55758)
2014 Jeep Patriot...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2017 KUBOTA SSV65 SKID STEER (A52706)
2017 KUBOTA SSV65...
Giyi Auger (A53316)
Giyi Auger (A53316)
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
