Stihl String Trimmers... I need a LONGER shaft.
   / Stihl String Trimmers... I need a LONGER shaft. #11
I have the Stihl F450 weed eater. Its a MONSTER. I had to purchase the Stihl shoulder harness to make it comfortable. You might see if a shoulder harness would allow the weed whacker to sit lower on your body and work better. Shoulder harness is, for sure, cheaper than some new type of whacker.
I had a standard weed trimmer that I converted into a combi-system. I bought the Stihl shaft extension and modified it to use in place of the original long weed trimmer shaft.
The extension shaft is a little longer than the stock combi-head unit shaft so that might help you. I left mine longer to give me a little more reach on my pole saw and hedge trimmer attachments.
FYI It's an easy conversion you won't need a machine shop to make it work.
THAT is an interesting idea. I'll have to check it out. If I can rig the extension in PLACE of the original shaft, that might solve everything I need without adding the complexity of an interceding 6" shaft and its inherent connections and failure points. I'll have to take a look at the shaft lengths and see whether that might be the ticket I needed from the beginning.
   / Stihl String Trimmers... I need a LONGER shaft. #13
FYI It was waaay cheaper to buy and mod the extension pole than buying the parts for the actual combi head unit.
I just wish I could get the bicycle handlebars for weed eating at a better price...the dealer was asking stupid money for the parts. The OEM D-handle is great if you want to get carpal tunnel.
Hope it works for you!
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
