Stihl String Trimmers... I need a LONGER shaft.
   / Stihl String Trimmers... I need a LONGER shaft. #11
I have the Stihl F450 weed eater. Its a MONSTER. I had to purchase the Stihl shoulder harness to make it comfortable. You might see if a shoulder harness would allow the weed whacker to sit lower on your body and work better. Shoulder harness is, for sure, cheaper than some new type of whacker.
I had a standard weed trimmer that I converted into a combi-system. I bought the Stihl shaft extension and modified it to use in place of the original long weed trimmer shaft.
The extension shaft is a little longer than the stock combi-head unit shaft so that might help you. I left mine longer to give me a little more reach on my pole saw and hedge trimmer attachments.
FYI It's an easy conversion you won't need a machine shop to make it work.
THAT is an interesting idea. I'll have to check it out. If I can rig the extension in PLACE of the original shaft, that might solve everything I need without adding the complexity of an interceding 6" shaft and its inherent connections and failure points. I'll have to take a look at the shaft lengths and see whether that might be the ticket I needed from the beginning.
   / Stihl String Trimmers... I need a LONGER shaft. #13
FYI It was waaay cheaper to buy and mod the extension pole than buying the parts for the actual combi head unit.
I just wish I could get the bicycle handlebars for weed eating at a better price...the dealer was asking stupid money for the parts. The OEM D-handle is great if you want to get carpal tunnel.
Hope it works for you!
Quick Attach Adjustable Forks (A59814)
Quick Attach...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
