stihl oil cap
/ stihl oil cap #21
Give me a minute,,,,gota clean the keyboard. :laughing::laughing::laughing:
But it works that way as designed. Reminds you to put the caps back on :)
Of course I have never, ever oiled my pants...since the last time anyhow.
Harry K
/ stihl oil cap #22
I now run 3 Stihle (210/310/361) all with the flippies. No problems at all and the 310 has put out around 50 cords over the years.
I have had them 'feel' like they were on but not and usually that results in the cap then being in the 'locked' position. Just pick it up, grab base with one hand, bail with other and 1/4 turn to the left - ready to reinstall.
My opinion of them: I don't mind them but it seems like it was a solution to a non-existant problem. Screw caps worked just fine.
Harry K
/ stihl oil cap #24
Yeah, They are crappy ... and look ay the $ spent on design compexity to replace something superior. Still, demonstration by klutzes is not productive.
Just learn how to use them or return the brand new saw with that as the reason
Found this link.
http://www.forestryforum.com/board/index.php?action=printpage;topic=34719.0
Even has a suggested fix. I haven't tried it yet, but will let you know if it works for me.
Wedge
Post#15: I had a lot of trouble when I 1st got mine. The cap mechanism engages and draws up as you turn it into place. Somehow on the 1st fillup I got mine in the drawn up position before trying to turn it -- so it wouldnt turn. What i had to do is engage the slots and turn it 1/4turn ccw to return it to "ready". Then place the cap in with the fold out butterfly handle oriented vertical, hold in gently and turn it til the handle was horizontal. This engaged the dogs and drew the O-ring seal into place. Success.:thumbsup:
larry
QED.
larry
/ stihl oil cap #25
Husqvarna
Once you go orange you will wonder why you spent all that time futzing around with anything else.
/ stihl oil cap #28
That guys a flipping idiot. :laughing:
You could extrapolate only a little and get "hold chain - pull this funny lever".:rolleyes:
larry
/ stihl oil cap #29
the oil cap on my sthil wouldn't seat so I compared the two caps and the o ring wasn't seated on the cap.I squeezed it tight and so far it's working. russ
/ stihl oil cap #30
Ive always had Stihl's , I bought a new 381 a couple of months ago and it will be the last . I have never seen such a stupid idea in my life . Fiddly stinking things that WILL fail , so I now need to carry two spares . And I too have oiled my new suede boots and trouser leg . Also , a screw cap is self adjusting so the seal is always snug , what happens when the seal on a flip cap starts to leak ? I also hate that they MUST be installed with your fingers so you get fuel and oil on your fingers or gloves where as the screw caps can be installed with the tool without really touching them .
/ stihl oil cap #31
Really,,,?, your not going to buy another Stihl because you can't operate a fuel cap ?
/ stihl oil cap #33
Just answer the question please, we can talk about your 'feelings' in different thread.
/ stihl oil cap #34
Mfg should not replace something that is perfectly good with something having no inherent benefit ... and at the same time screw up the replacement. Were paying for this you know. :mad:
larry
/ stihl oil cap #35
And yet another sarcastic comment from you . Are you going for a record ?
Like I have to explain to you that I am buying Husqvarna next time because they don't have bits on them that will let me down 2 miles from my truck .
/ stihl oil cap #36
I just got an MS290 with the flip-caps and was concerned (because of posts like these) but after 20+ hours I have had zero issues with them. They require a bit more care when putting them back on. You can't just drop them in and spin them. You have to line it up, it only goes in one way. I appreciate the quarter turn and positive lock design.
My suggestion would be make some alignment marks on the saw and the cap to help you guys line it back up correctly. Turn the cap to the position where you can lift it out and mark the saw and the cap with an engraver bit or something that won't be deminished by the oil, and then just use the alignment marks to help you get them back on strait.
I have had one instance where the bit of sting that keeps the cap from wandering off get caught but that was just error on my part.
/ stihl oil cap #37
Put me down as another NON fan of the flippy cap. STUPID idea! Great saws but the WORST caps EVER!
/ stihl oil cap #38
I think the first person that comes up with a course thread plastic screw cap that can utilise the partial thread that is now moulded in the case that will replace these non adjustable pieces of .... will make a killing . Hmmmmmmm how much IS an injection moulder ?:D
/ stihl oil cap #39
You don't need to buy an injection molder Iron Horse. Just design the caps, state a quantity desired, post your drawings on mfg.com and you will get numerous quotes on the job. The quotes may be from anywhere in the world and pricing may be all over the place. It is an excellent resource for anyone that wants something made, has a design, but does'nt have the equipment available. Also, all the manufacturers that have did business previously have received ratings from the purchaser - think Ebay feedback. Check it out as it is free for the folks submitting designs for quote - those quoting the jobs do the paying for the service.
/ stihl oil cap #40
Just wait..... I liked the idea at first too. Wait until you dump bar oil down the front of your leg while cutting a tree. Wait until you spend 10 minutes in 95 degree heat trying to get that %#$^@# cap on right.
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
Landhonor 3Pt Stump Grinder (A66408)
Landhonor 3Pt...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
3'6"x5'6" Aluminum pickup Roller Tray (A62679)
3'6"x5'6" Aluminum...
