stihl ms290 won't start
/ stihl ms290 won't start #1
MississippiMan
Mississippi
Mahindra 5525
I had broken some plastic pieces on the housing and chain brake so I replaced them. While doing so I removed the carb and cleaned it. Put it all back together and it started normally and then quit in about 2-3 seconds. It did this 5-6 times. It would never idle on it's own. So I got the service manual and removed the carb again meticulously making sure I reassembled everything correctly and installed the carb correctly. Hoses, lines,electrical, everything by the book. Carb was already properly adjusted but I checked that too.
Now it won't turn over and eventually after many pulls I saw gas spray out of the muffler. So I removed it and I am drying that out at the moment. I guess I flooded the engine but why? Possibly getting no spark. I'll have to check for that next but I have an appointment to keep now.
Any ideas would be appreciated.
Every line and every screen and filter is clean and it appears to be ample fuel.
Help. It was running great when I put it away last week.:confused:
/ stihl ms290 won't start #2
Sparkplug is most likely fouled. Check sparkplug wire for break or no contact. Check the on/off switch. Depending on how the pieces ended up broken could identify other damage (broken wires, etc.).
/ stihl ms290 won't start #3
Also inspect the black accordion like fuel hose, they are known to split .
spark plug is new with correct gap. Will give close look at fuel line and wiring in the morning.
/ stihl ms290 won't start #5
Is the fuel fresh?
2021 Chevrolet Silverado 2500 HD Single Cab Royal Service Truck (A64194)
2021 Chevrolet...
2022 EZ-GO ELITE...
Case IH Magnum 380 (A64126)
Case IH Magnum 380...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
CATERPILLAR CS44B...
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
