Stihl MS250 rebuild.
   / Stihl MS250 rebuild.
I ran another tank of fuel through it again and thought I had a problem. It would stumble when throttling up and then finally wouldn’t run. It was just a loose plug wire.
One problem I have had with the saw is the chain will freeze up. It acts like it’s over tightened but it’s not. If I loosen and the work the chain back and forth and tighten again it’s fine. I assume it’s sawdust building up under the cover?
   / Stihl MS250 rebuild. #52
Might be, that's easy to check.
I remove the clutch cover and clean the saw every 2 tanks at most, when I sharpen the chain and flip the bar.
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2013 Ford F-750 Truck, VIN # 3FRXF7FL2DV789551 (A57453)
2013 Ford F-750...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
NEW Long Forks (A59000)
NEW Long Forks...
