Stihl MS250 rebuild.
   / Stihl MS250 rebuild.
I ran another tank of fuel through it again and thought I had a problem. It would stumble when throttling up and then finally wouldn’t run. It was just a loose plug wire.
One problem I have had with the saw is the chain will freeze up. It acts like it’s over tightened but it’s not. If I loosen and the work the chain back and forth and tighten again it’s fine. I assume it’s sawdust building up under the cover?
   / Stihl MS250 rebuild. #52
Might be, that's easy to check.
I remove the clutch cover and clean the saw every 2 tanks at most, when I sharpen the chain and flip the bar.
NEW Landhonor LHR=EPC40 Plasma Cutter (A59000)
NEW Landhonor...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2005 JOHN DEERE 317 SKID STEER (A52709)
2005 JOHN DEERE...
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
