Stihl MS 261 C-M 18" vs 20" Bar
   / Stihl MS 261 C-M 18" vs 20" Bar #1
Johnkn
Platinum Member
Laplata, MD
Kubota LX3310
Greetings, getting ready to get a MS261 C-M, really torn between the 18" and 20" bar. My current (early 1970's) saw has a 21" bar and cuts like a beast but is heavy as **** on this old body. I was really thinking about the 20" bar on the new saw, not really for any potential cutting advantage, but so I don't have to bend over quite so far when limbing fallen trees. Not sure what the weight difference is between the 2 saws, an extra 2" of bar and 4" of chain can't be more than a few ozs. I'm sure either length would be fine. Suggestions? thanks
   / Stihl MS 261 C-M 18" vs 20" Bar #2
I would recommend against the 20" bar -- it makes the saw too nose heavy, and unbalanced (it won't even sit flat on a table with a 20" bar). The saw can pull a 20" bar in softwood, but not in hardwood, so it's of limited use anyhow. It'd stick with 16" or 18" bar. I have all three sizes for my 261, and 18" is the most versatile.
If you really need a 20" bar, I'd step up to a 60cc saw. In that size range, the Husky 562XP is the best option right now.
   / Stihl MS 261 C-M 18" vs 20" Bar #3
Tough choice. My personal preference might be for a 16" and a 20". The weight of the longer bar isn't much, but it's all the way out at the end of the lever. The shorter bar will feel quite a bit lighter. I also don't think two extra inches will make much of a difference as far as bending over is concerned. Of course, it also depends on the size of wood you're working with "right there". If I had to choose one, I'd buy the 18". I have a Shindaiwa 488, which is the same size saw. It came with a 20" bar. I'm looking for a shorter one to swap it with.
   / Stihl MS 261 C-M 18" vs 20" Bar #4
I recently purchased an MS 261 C-M and went back and forth between 16" and 18" for the bar. I ended up going with 16" and I'm really glad that I did. My logic at the time was that I'd get the 16" saw, which will cut nearly everything I have to deal with at my place, and then get a 20" bar for the times when I need a bit more capacity. I still haven't needed the longer bar (the couple times I've cut something bigger, I've had a buddy there helping and he had a bigger saw with him), but I won't mind buying it when I do.
I love the way my saw cuts with a 16" bar. Since it's perfect for 99% of my cutting, I'm glad that I didn't compromise.
A shorter bar will really increase your satisfaction with a chainsaw. My father-in-law uses a 16" bar on his MS 440!
   / Stihl MS 261 C-M 18" vs 20" Bar #5
I run a 16" bar on my 260, and could not imagine running a longer bar-of course I cut hardwoods.
Will
Sent from my iPhone using TractorByNet
   / Stihl MS 261 C-M 18" vs 20" Bar #6
Will
I don't know how much of a difference it is in the field, but the MS 260 is 3.5 HP and the MS 261 has 3.9 HP. I've been running mine with a 16" bar and it's been in the single digits here, but my saw is ripping through the frozen solid walnut I've been cutting lately. It will make a pile of chips fast when I bury the bar in a big section of the trunk. I wouldn't hesitate to run it with an 18" bar if I had a lot of logs that big around, and I'm sure it will run a 20" bar with no problem if I need one for occasional use. However, if I found that I needed a 20" bar all the time, I'd be looking at a bigger saw to go with it.
   / Stihl MS 261 C-M 18" vs 20" Bar #7
Don't know your real requirements but I am with those that opt for a shorter bar. I am getting older and like the shorter bar because it seems much easier to swing it around. I got rid of my old saw with a 20in bar because I really didn't need the length ever.
Thank you everyone, appreciate your comments. I was debating on either a 18" or 20" bar with the thought that the 20" bar would be easier on my (old) back when limbing down trees, but I think good sense will prevail and I'll go with the 18" on this one. I only use the saw a handful of times a year, I'm sure it will be fine. I'll post here when I get it. take care
   / Stihl MS 261 C-M 18" vs 20" Bar #9
I think that's a good call. Especially if most of your work is small stuff, limbing, etc. At least that is what I found. I hear you on the leaning over and back thing but I don't think the longer bar will really do that much for you and you will have less control. I use my little guy for limbs even though it isn't as nice a saw just because of the weight and control.
   / Stihl MS 261 C-M 18" vs 20" Bar #10
Don't let me nay-say buying a pro saw. I almost always recommend that people step up to the pro level of saws even for homeowner use. That said, though, if you will really only use it a few times a year, a ms251, or whatever they call it now might work for you. Just something to think about. If you've got the cash, and want to have a really fun saw, then forget I said anything.
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
WB 17" PIN ON EXCAVATOR BUCKET (A52707)
WB 17" PIN ON...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
