Stihl MS 261 C-M 18" vs 20" Bar
   / Stihl MS 261 C-M 18" vs 20" Bar #1
Johnkn
Platinum Member
Laplata, MD
Kubota LX3310
Greetings, getting ready to get a MS261 C-M, really torn between the 18" and 20" bar. My current (early 1970's) saw has a 21" bar and cuts like a beast but is heavy as **** on this old body. I was really thinking about the 20" bar on the new saw, not really for any potential cutting advantage, but so I don't have to bend over quite so far when limbing fallen trees. Not sure what the weight difference is between the 2 saws, an extra 2" of bar and 4" of chain can't be more than a few ozs. I'm sure either length would be fine. Suggestions? thanks
   / Stihl MS 261 C-M 18" vs 20" Bar #2
I would recommend against the 20" bar -- it makes the saw too nose heavy, and unbalanced (it won't even sit flat on a table with a 20" bar). The saw can pull a 20" bar in softwood, but not in hardwood, so it's of limited use anyhow. It'd stick with 16" or 18" bar. I have all three sizes for my 261, and 18" is the most versatile.
If you really need a 20" bar, I'd step up to a 60cc saw. In that size range, the Husky 562XP is the best option right now.
   / Stihl MS 261 C-M 18" vs 20" Bar #3
Tough choice. My personal preference might be for a 16" and a 20". The weight of the longer bar isn't much, but it's all the way out at the end of the lever. The shorter bar will feel quite a bit lighter. I also don't think two extra inches will make much of a difference as far as bending over is concerned. Of course, it also depends on the size of wood you're working with "right there". If I had to choose one, I'd buy the 18". I have a Shindaiwa 488, which is the same size saw. It came with a 20" bar. I'm looking for a shorter one to swap it with.
   / Stihl MS 261 C-M 18" vs 20" Bar #4
I recently purchased an MS 261 C-M and went back and forth between 16" and 18" for the bar. I ended up going with 16" and I'm really glad that I did. My logic at the time was that I'd get the 16" saw, which will cut nearly everything I have to deal with at my place, and then get a 20" bar for the times when I need a bit more capacity. I still haven't needed the longer bar (the couple times I've cut something bigger, I've had a buddy there helping and he had a bigger saw with him), but I won't mind buying it when I do.
I love the way my saw cuts with a 16" bar. Since it's perfect for 99% of my cutting, I'm glad that I didn't compromise.
A shorter bar will really increase your satisfaction with a chainsaw. My father-in-law uses a 16" bar on his MS 440!
   / Stihl MS 261 C-M 18" vs 20" Bar #5
I run a 16" bar on my 260, and could not imagine running a longer bar-of course I cut hardwoods.
Will
Sent from my iPhone using TractorByNet
   / Stihl MS 261 C-M 18" vs 20" Bar #6
Will
I don't know how much of a difference it is in the field, but the MS 260 is 3.5 HP and the MS 261 has 3.9 HP. I've been running mine with a 16" bar and it's been in the single digits here, but my saw is ripping through the frozen solid walnut I've been cutting lately. It will make a pile of chips fast when I bury the bar in a big section of the trunk. I wouldn't hesitate to run it with an 18" bar if I had a lot of logs that big around, and I'm sure it will run a 20" bar with no problem if I need one for occasional use. However, if I found that I needed a 20" bar all the time, I'd be looking at a bigger saw to go with it.
   / Stihl MS 261 C-M 18" vs 20" Bar #7
Don't know your real requirements but I am with those that opt for a shorter bar. I am getting older and like the shorter bar because it seems much easier to swing it around. I got rid of my old saw with a 20in bar because I really didn't need the length ever.
Thank you everyone, appreciate your comments. I was debating on either a 18" or 20" bar with the thought that the 20" bar would be easier on my (old) back when limbing down trees, but I think good sense will prevail and I'll go with the 18" on this one. I only use the saw a handful of times a year, I'm sure it will be fine. I'll post here when I get it. take care
   / Stihl MS 261 C-M 18" vs 20" Bar #9
I think that's a good call. Especially if most of your work is small stuff, limbing, etc. At least that is what I found. I hear you on the leaning over and back thing but I don't think the longer bar will really do that much for you and you will have less control. I use my little guy for limbs even though it isn't as nice a saw just because of the weight and control.
   / Stihl MS 261 C-M 18" vs 20" Bar #10
Don't let me nay-say buying a pro saw. I almost always recommend that people step up to the pro level of saws even for homeowner use. That said, though, if you will really only use it a few times a year, a ms251, or whatever they call it now might work for you. Just something to think about. If you've got the cash, and want to have a really fun saw, then forget I said anything.
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52707)
2017 FECON RTF140...
2014 Ford F-250 4x4 Ext. Cab 8ft. Flatbed Truck (A55852)
2014 Ford F-250...
1541 (A57192)
1541 (A57192)
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
