Sticky HST pedal
/ Sticky HST pedal #1
Retired guy
Western, ME
CK 30HST
The rocker pedal on my CK30 HST has begun rebounding slowly. I have greased the zerk, cleaned the rod and oiled the linkage.
It is a 2012 with 2660 hours. Suggestions
/ Sticky HST pedal #2
Same as mine, albeit a 2014 with only about 700 hours on it. Seems to be worse when tractor is first started and not as pronounced after it’s warmed up with use.
Subscribed to hear solutions…😉
/ Sticky HST pedal #3
Any debris jammed up in the peddle linkage? I had that issue once, and it kinda spoked me when the Forward peddle didn't come up, when I lifted my foot. Shut it down, and found a stick had wedged in there and kept it from returning.
/ Sticky HST pedal #4
Did you read his post?
/ Sticky HST pedal #5
My Branson does this when cold and the grease is stiff. I tried some low temp grease and that seemed to help a little.
/ Sticky HST pedal #6
I had that problem with my CK30. Dealer said the shaft where it goes into the transmission fit very tightly and it was difficult to get it lubed properly. He ended up pulling the case apart, removing the shaft, sanding down the shaft and cleaning up the hole it fit in. This gave just enough clearance to grease it up properly before reassembling. Supposedly worked fine after that. I traded the CK30 in for a DK40 and never used it after dealer fixed it. Sometimes I wish I had kept the CK.
/ Sticky HST pedal #7
NH TC29D has same issue. But, comes and goes. All it takes is a light tap on reverse end of pedal, and it stops the forward motion. It's not like it is running full steam, it just doesn't return to neutral position. And it's only when running, I think. Peddle seems to move freely when I'm trying to fix issue. Unless it is such a slight hang up that I don't see. It's a head scratcher for sure...
/ Sticky HST pedal #8
Kioti installed 3 new transmissions in my CK27 it still stuck often then they tried a $600 fix then they added an extra spring to the return. It still stuck some times where I had to give a hard kick to release it. When it stuck and I flipped over backwards I took the tractor back to the dealer and told them to keep it ,600 hrs. on it . They sold me a 2610 real cheap with 2 pedals it still sticks when cold but not as severe I now have 1200 + hrs. on it. I think they need to rethink their transmissions.
/ Sticky HST pedal #9
It's not about blaming the person who’s forced into a horrible situation, but about focusing on the person who’s abusing their power. The boss is in the wrong here, and the victim is just trying to survive in a terrible position. We should be looking at how to stop people from using their power in such an awful way and how to bring those responsible to justice.
I don't think you posted in the correct thread.
/ Sticky HST pedal #10
My 2010 Ck30, with 900 hrs, does the same as yours and Retired Guy. I gave up on greasing or oiling as it doesn't seem to make any diff. It does seem to warm up a bit sooner than it used to and then its ok.
My problem, over the years, is forgetting to release the brake pedal lock and now the brakes are half worn out! LOL
/ Sticky HST pedal #11
With all the HST peddles sticking complaints on so many different models and manufacturers, it has become obvious this is a design issue.
I have a New Holland TZ25DA with the same issue. Doesn't seem to be as bad after it's been running and is warmed up, but it never is to may satisfaction. After studying the mechanics of how the peddle returns, I have decided the damping cylinder is contributing to this problem. I will be disconnecting the damping unit later this month to see if there is any change in how fast the HST returns.
I have a very old Deere 425 with about 1200 hours that doesn't seem to suffer from this issue. I will also take another look at it's return system to see how different it is from the TZ25.
/ Sticky HST pedal #12
Hello t_bois1!
My CK30 has same problem. Did disconecting of the damping cylinder solve this issue or what is the best fix?
KMC 4 ROW BED SHAPER (A60430)
KMC 4 ROW BED...
2009 Arco Trailer T/A 6,000 Gallon Tank Trailer (A59230)
2009 Arco Trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Toyota Tacoma Crew Cab Pickup Truck (A59230)
2020 Toyota Tacoma...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
80" BOX BLADE (A60430)
