ArtVandelay
Bronze Member
- Joined
- Jun 22, 2007
- Messages
- 50
For mowing approximately 9 acres of pasture with a rotary cutter, which is better, a stick-shift or automatic tractor?
Thanks.
Thanks.
A Manual with PowerShuttle.ArtVandelay said:For mowing approximately 9 acres of pasture with a rotary cutter, which is better, a stick-shift or automatic tractor?
Thanks.
Thanks.
art said:Can't deny that the gear will get the job done but one of the biggest pluses with a hydro is speed flexibility or ability to fit the conditions. There are times a field is rough or has objects that you need to mow around and the hydro with it's infinite speeds makes it tough to beat for speed when trying to get a job done. The ability to quickly and effortlessly adjust the ground speed to the conditions of the ground or even a light spot where you might enjoy a little faster ground speed is a big plus for the hydro's. Like mentioned before if a loader might be used the the hydro will also be a plus.
The hydro is also a very easy tractor to teach a new operator how to operate compared to a gear drive. It even makes a difference in the primary operator as we've seen clutches out at 500 hours before just from the way the tractors are used which quickly levels the price difference of the hydro. What you might loose in efficency in fuel with a hydro you might gain in time if that is a concern. Depending on the size of the tractor and mower would also make a difference as to the initial cost which is important to many.
art said:one of the biggest pluses with a hydro is speed flexibility or ability to fit the conditions. There are times a field is rough or has objects that you need to mow around and the hydro with it's infinite speeds makes it tough to beat for speed when trying to get a job done. The ability to quickly and effortlessly adjust the ground speed to the conditions of the ground or even a light spot where you might enjoy a little faster ground speed is a big plus for the hydro's.
