Stick or MIG on thick plate???
   / Stick or MIG on thick plate??? #41
Yea, I was going to order the roller and liner but now since the wire is going to be a pain to get I think I will just get some Lincoln .035 NR211 and be done with it. It is easy to get and I'm sure it will work fine.
yeah, earlier this year i bought a miller 211 and i was going to get the 045 stuff for it too, but the more i thought about it, the less i decided i needed it. it's not too often i get past 1/2" material. generally 1/8" to 1/2" is what i use.
   / Stick or MIG on thick plate??? #42
I went to my LWS to get the dual shield wire today, I wanted the ESAB .045 E71T-1M/2M Dual Shield II 70 Ultra. The guy told me it is only available in 9in or 12in spools. The Hobart Handler 210 I just bought can only handle spools up to 8in.
Does anyone know were to get this wire in 8in or smaller spools?
That ESAB wire is what we use. Its a great wire. Too bad it won't fit your machine. I'm guessing that all manufacturers have an equivalent wire. I gather it doesn't come in the small rolls in .035 either? Lincoln's NR211 runs pretty good, but if you've ever run a dual shield wire, its hard to go back to that. The slag formed on dual shield just falls off with a tap. Sometimes will just curl off behind you on a long bead. NR211 will take some effort with a chipping hammer and a wire brush to clean up. I'd invest in a needle scaler if thats what you are going to use and you have an air compressor. I believe NR211 is a 60,000 tensile wire while the II 70 Ultra is 70,000. The II 70 also has really good cold weather properties. Neither of those would likely be issues for your backhoe project. The good thing about the NR211 is it will be cheaper and you don't need to buy gas.
Kim
   / Stick or MIG on thick plate??? #43
I know conventional wisdom says use a stick welder for thick plate. But I have never used stick and I worry its going to be difficult for me to weld using a stick. I am getting older and my hands are not as steady as they used to be especially after a couple of beers.
At school, we had to learn to weld on 3mm plates with O/A torches. Just to get the feel, to control a melting bath. Then stick welding, then mig welding.
stick welding is the most easy way of welding, just set the amps right and drag the rod along slowly. If you know how to adjust a mig welder, wire feed, amps, stick welding is peanuts.
My question is, can the MIG Pro 180 (or any 180A MIG) really weld 1/2" plate? If so how difficult is it to get good penetration, any hints, advice?
Dont waste your money on another toy: I used to have a 180A welder with my brother: It cost 700 euro, and 350 of repairs every 2 years. When it broke down, i got a loaner: It was a 250A semi commercial model: What a world of difference !! This really made welding fun !
Because i didnt want to risk to break my brothers welder again, when it was repaired i brought it straight away to my brothers backgarden shop in town, and ordered myself a new commercial 350A welder. It was 1400 euro new: I spent the same money on the hobby 180A welder, and two 350 euro repairs (once the main spool, the other time the rectifier) in 4 years time, because i only used the max setting, and it still came short on heavy steel.
For what i'm doing (mostly half inch as well) the difference between our old 180A hobby, and the 250A semi-commercial loaner, was a giant leap, where the difference between the 250A semi-commercial loaner, and the 350A commercial i bought, was just a big step.
My advice: Dont end up with TWO toys: save your money untill you can afford a 250A mig. Its worth it !
What is the general opinion on using MIG for thick plate?
Just visit the attic of the welding company i worked: They have about a ton of unused welding rods from the old times... There is too much money in it to throw them away, but the hourly wages are too high nowadays to give workers a box of sticks and a slag hammer...
   / Stick or MIG on thick plate??? #44
I do not see any advantage using 0.045 Dual Shield wire with a marginally power unit and all its complexities.
Looking through my Miller GMAW manual which exlapains Short Arc Transfer, Gobbler Transfer and Spray Arc Transfer and what takes to makes it happen, I would choose a 0.035, ER70S-6 or ER80-6 wire.
Short Arc Transfer with C-25 gas:
0.035, 50-180 amps, 16-22 arc volts.
0.045, 75-250 amps, 17-23 arc volts.
Spray Arc Transfer with Ar+1 to 5%O2, C-25 may also be used by adding another volt or two to the arc volts.
0.035, 165-300 amps, 24-30 arc volts.
0.045, 200-375 amps, 24-32 arc volts.
I would prep the joint with a signal or two sided V notch as needed, set the root gape at 0.035 using the wire as a gauge, a hot tack weld, run the root pass in Short Arc mode hot enough to get penetration without too much burn through if any. Setup for Spray Arc Transfer to fill the V notch, plenty of heat to tie in the sides of the notch. Compensate for distortion by welding side 1 than side 2. Take care for silicon slag islands [grind or chip our] cap the gap and call it a day.
   / Stick or MIG on thick plate??? #45
Its also a big leap from a $700 machine to a $2500 Machine. I know this is a build your own site but I can tell you a backhoe is so much fun, I would buy the $700 welder and put the 1,800 you saved on the welder plus the $3,000 your gonna spend on the backhoe project and buy a 3pth backhoe and go digging next weekend instead of next summer :)
   / Stick or MIG on thick plate??? #46
Yes, that is the route I would take, but some folk like to roll their own.
   / Stick or MIG on thick plate??? #47
Can't argue with anything here. I kind of wondered if a 210 would have enough poop to run .045 good. He might be better off with .035. I believe it was Shield Arc that showed a picture of .045 vertical run with a 200 amp machine. Pretty good jump in deposit rate between .035 and .045. I normally run .045 ER706-6 on my 255 at home because I don't have smoke extraction and don't want to smoke up my shop walls and ceiling. 90% of what is run at work is II 70 Ultra. I prefer it over the hardwire, especially out of position, but maybe that is just me and my lack of experience running hard wire out of position. I usually have to run it downhill which doesn't have the penetration of uphill.
Kim
   / Stick or MIG on thick plate??? #48
JCC, just for kicks a story from back in the 90's when I spent a few years working on oil platform modules and building a new refinery from scratch (along with 10000 others...).
Since the refinery was a government project, the operating "company" (also government people) decided that they could do as good as the suppliers and bid on some of the "easy" piping for the refinery. Typically it consisted of welding standard lengths of pipe together and then welding one standard pipe fitting (elbow or T) on each end. Given the standard welding position and working indoors, 90% of the welds were mig. They were easily recognizable due to the smooth consistency of the weld bead, since the process was essentially automated (fixed torch position and rotator for the pipe.
Bear in mind this was a Loyds insured project, so all welders had to be qualified and regularly re-tested and the welds inspected according to the duty and typically BS specifications. Generally, the welds are sampled and this switches over to 100% if issues are found with workmanship of a particular welder. The majority of the pipes were too thin for ultrasound inspection (need at least 3/4" wall) so radiography and magnetic particle were the rule, with visual inspection too.
So the government contractor delivers over 120 000 "spool pieces" (the prefabricated pipe sections) to the refinery site, along with a couple of container loads of quality documentation (no joke, it was like a library).
Other contractors, like Chicago Bridge and Iron (one of the best on site) take the pre-fabricated parts and assemble them on site in situ. Much harder work, done outside in the weather, the material is immobile, so uphand, downhand and overhead welding are all required, to the same exacting quality standards. So this is where I enter the picture. Having been an NDT technician and having studied engineering and being able to work with engineering drawings, I got a job as a coordinator who goes out, marks the welds to be inspected, sometimes arranges for scaffolding to be built to get to the joint to be tested, and then shows each NDT crew where there work is for the shift.
Well, it happens that in the pitch dark of night on a refinery site that consists more of rain filled excavations than visible structures that one of the radiographers (hung over perhaps) X rays the wrong welds. Good boy that he is, he marks the locations properly that he DID xray, so the next day when it is found that all the welds he radiographed had 100% lack of fusion, it didn't take long to figure out what happened. Instead of X raying the NEW field welds, he X rayed the MIG welds made by the government contractor, which had been sandblasted and painted before being shipped to the site. Seeing the paint in the location of the failed welds and then seeing the characteristic smooth weld beads one has the instant AHA moment. Mig welds + wrong prep or parameters = LACK of FUSION. No matter how pretty the welds, most of them were junk.
To cut a long story short, fixing the mig weld problem took about 20 full time bodies working lots of overtime nearly 2 years. The final repair rate on the mig welds was over 60%.
So my advice is: always guard against too little heat input. Preheat the joint well with a "rosebud" or OA torch. If using true mig (not flux core), everything has to be scrupulously clean. With stick welding, the flux does more than just provide shielding against oxygen. If stick welding, always de-humidify the rods in your wifes oven, or get your own toaster oven.
Bottom line, always consider the consequences of failure of the joint and act appropriately. While mig can be used for larger thickness joints, the configurations is always "qualified" before actually being used, just like what is done for stick or any other process. Just be aware that the tendency for "cold welds" is always there when doing mig welding.
   / Stick or MIG on thick plate??? #49
Yes, that is why 0.035 flux core wire runs hotter than 0.035 solid wire. The cross sectional area of flux core is less than solid wire and for the same current, the current density is [amps/ Sq in] is higher.
Buying a backhoe was one of my options, but one of the main attractions for me to build one myself is the enjoyment of the project and being able to design exactly what I want.
Also buying a good 3pt backhoe would set me back $6-$7K and I do not like 3pt but prefer a subframe mount which would be even more. I figure DIY will cost me about $2500 not including the welder (which will be used for a long time to come) and not counting my hourly rate (but that is another thread).
I do not mind the time it will take, that is why I decided to get a better MIG not a stick welder even though it will take probably 5 times longer to complete the couple dozen welds on 1/2" plate. Since the vast majority of my other projects will be just fine with the Handler 210 it makes more sense for me.
If I was just interested in convenience I would just hire the backhoe work done.
   / Stick or MIG on thick plate??? #51
the lincoln nr-211 is a 58ksi yeild and 70ksi tensile wire. i'd say it's the comparable wire to the esab coreshield 11 - both are classed as e71t-11. esab rates their wire much higher than lincoln for yeild and tensile, though both are rated high enough to exceed the yeild and tensile of a36 and a572gr50 steel, which are the most common grades you will see.
   / Stick or MIG on thick plate??? #52
JCC, have you factored in the time and expense to de-bug the hoe when things go wrong?
I'm sure things will go wrong, but isn't that the fun in these projects, making things work?
I can't stress the fact that a big part of this backhoe project for me is the fun of it. I enjoy the design, materials hunt, learning new things like in this thread and the new shop toys I will need to get to do a project like this. I am not going to have my accountant looking over my shoulder making sure there are no cost overruns.
   / Stick or MIG on thick plate??? #54
Hey all. I built one the the caddiggers about 10 years ago. I had always mig welded but never arc welded. I bought a lincoln ac/dc stick and used 7018 rod. turned out pretty good. I'm not real steady. I have put that backhoe thru everything and you couldnt, bend the steel if you wanted to. it was overdesigned i think for toughness. Just make sure you have plenty of penetration and you will be fine.
pictures of mine, search arkydog.
   / Stick or MIG on thick plate??? #55
Ok, as long as you are taking on this project with your eyes open.
   / Stick or MIG on thick plate??? #56
I ordered my new welder with a 4 meter torch hose package, instead of the standard 3 meter. but with 0.8mm wire i had to cut it out between the wire feed rolls every time, because it kinked. Now i use 1mm wire and i have no more problems.
Wire thickness depends on how heavy you weld: Its hard to get a steady wire feed at very slow feed rates. So welding tiny welds on auto bodywork with 1mm wire is not going to work very well, because the wire feed rate is unstable at this speed.
With a long torch hose, you'll benefit from thicker wire because it doesnt kink as quickly, so you can apply more pressure to the feed rolls, so it will push through when you start welding again, after the last bit of wire melted a little to the tip.
   / Stick or MIG on thick plate??? #57
Think Spool Gun.
   / Stick or MIG on thick plate??? #59
Hi I am a newbe here
I have been using my little Lincoln Weldpak-100 for some repair here and there it seem to work ok for that. Now I try to build myself a dump trailer which require something more heavy duty weld on frame work. I have look into gettting a new Millermatic211 for little over $1300 but there is one used Millermatic passport plus list on Craiglist for 1/2 price for it's new the guy said he hardly use it.
My question is beside it's portable and such a light way. Does that unit really work as well as the millermatic211? any suggestion or advice would be apreciated. thanks
   / Stick or MIG on thick plate??? #60
O.k. its called a spool gun ? In Dutch its the same word for O/A, rod and wire torches/guns...
learning every day :)
What you have is not a spool gun, it is a conventional torch handle. Transit is suggesting that you use a spool gun when you need to be a long distance away from the welding unit. The spool gun has the wire spool and drive motor in the handle so the wire is only pushed a couple of inches , it is commonly used for aluminium welding.
2014 GMC Sierra SLT 4x4 Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59904)
2019 INTERNATIONAL...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
JCB 2145 (A47477)
JCB 2145 (A47477)
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
