Sthil FS45
/ Sthil FS45 #1
Geochurchi
B&S Vangard
Hi All, having problems with the recoil starter pawl, it’s an aftermarket assembly with a white pawl, when I install the stater it pulls and turns over fine with the spark plug removed, when I reinstall the plug it snaps the white pin on the pawl.
Any Thought as to what I may be doing wrong.
Geo🇺🇸
/ Sthil FS45 #2
Sorry your having trouble. Can you post some photos of the parts.
Why did you replace the original parts ?
Richard
/ Sthil FS45
It was taken apart by someone else, I have since ordered an OEM pawl , hoping it’s better quality.
Thank for the reply
/ Sthil FS45
Hi, here’s what I know : Sthil mdl # FS46 C E2S , S/N 263985156, was running fine until the string broke at which time it was disassembled, and parts were lost, I have tried to install an OEM aftermarket starter, see pic’s, when installed and plug removed it pulls fine , when the plug is installed pull hard and snaps the pin off Of the pawl, is there a different starter for an EZ start?
Thanks
/ Sthil FS45 #5
Can you indicate in the photos that part that keeps breaking ?
I don't see it.
/ Sthil FS45
Hi, it should be FS46C , here is a pic.
/ Sthil FS45 #7
Your post heading identifies your Sthil as FS45, yet in your post #4 you identify it as FS46
Which is it ?
/ Sthil FS45
Yes , the black piece is mounted on the motor.
/ Sthil FS45 #11
Now we are cooking. First of all, you have a mismatch between the recoil starter type and the recoil item that is on the engine. The starter part that is bolted onto the engine as shown in your post #4, photo 4, requires the recoil starter as shown in photo 1 of post #4.
Here is a photo of a screen shot from a video, note that the recoil start item on the engine is a cup type;
If you want to use the recoil housing that you have, then you need to get this cup style item for the engine.
/ Sthil FS45
So you are saying the one I have listed as EZ start is the correct starter.
/ Sthil FS45 #13
Yes that would work with the item that is now bolted onto the crankshaft. You have choice of either getting a starter housing that will work with the item on the crank, or getting a different crank part that is like the cup that is shown in the photo that I took from a video. Then the recoil housing that you have will work with the cup type part.
I did not check on prices for the items.
/ Sthil FS45
Hi Richard, Thanks for taking the time to figure this out, I now know exactly what I need to go either way.
I did something I never do and threw out the original housing and guts, now I am paying for it, could have no doubt rebuilt that unit with new spring etc.
Seems difficult to get any kind of info about Sthil.
/ Sthil FS45
Hi, I am pretty sure I have , I order a used starter housing on E b, waiting for it to arrive, it should match the end that is on the motor, Ill let you know the outcome.
Thanks for asking.
Geo🇺🇸
/ Sthil FS45
Hi, anyone know what Dia the starter rope is?
P/S runs like new, starts with 3 pulls.
/ Sthil FS45
Hi All, is there a good video to show how to replace the starter cord on an EZ start Stihl FS45 weed eater, to prevent the spring from unwinding?
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
Deutz DX140 Tractor (A66285)
Deutz DX140...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
