Sthil FS45
/ Sthil FS45 #1
Geochurchi
B&S Vangard
Hi All, having problems with the recoil starter pawl, it’s an aftermarket assembly with a white pawl, when I install the stater it pulls and turns over fine with the spark plug removed, when I reinstall the plug it snaps the white pin on the pawl.
Any Thought as to what I may be doing wrong.
Geo🇺🇸
/ Sthil FS45 #2
Sorry your having trouble. Can you post some photos of the parts.
Why did you replace the original parts ?
Richard
/ Sthil FS45
It was taken apart by someone else, I have since ordered an OEM pawl , hoping it’s better quality.
Thank for the reply
/ Sthil FS45
Hi, here’s what I know : Sthil mdl # FS46 C E2S , S/N 263985156, was running fine until the string broke at which time it was disassembled, and parts were lost, I have tried to install an OEM aftermarket starter, see pic’s, when installed and plug removed it pulls fine , when the plug is installed pull hard and snaps the pin off Of the pawl, is there a different starter for an EZ start?
Thanks
/ Sthil FS45 #5
Can you indicate in the photos that part that keeps breaking ?
I don't see it.
/ Sthil FS45
Hi, it should be FS46C , here is a pic.
/ Sthil FS45 #7
Your post heading identifies your Sthil as FS45, yet in your post #4 you identify it as FS46
Which is it ?
/ Sthil FS45
Yes , the black piece is mounted on the motor.
/ Sthil FS45 #11
Now we are cooking. First of all, you have a mismatch between the recoil starter type and the recoil item that is on the engine. The starter part that is bolted onto the engine as shown in your post #4, photo 4, requires the recoil starter as shown in photo 1 of post #4.
Here is a photo of a screen shot from a video, note that the recoil start item on the engine is a cup type;
If you want to use the recoil housing that you have, then you need to get this cup style item for the engine.
/ Sthil FS45
So you are saying the one I have listed as EZ start is the correct starter.
/ Sthil FS45 #13
Yes that would work with the item that is now bolted onto the crankshaft. You have choice of either getting a starter housing that will work with the item on the crank, or getting a different crank part that is like the cup that is shown in the photo that I took from a video. Then the recoil housing that you have will work with the cup type part.
I did not check on prices for the items.
/ Sthil FS45
Hi Richard, Thanks for taking the time to figure this out, I now know exactly what I need to go either way.
I did something I never do and threw out the original housing and guts, now I am paying for it, could have no doubt rebuilt that unit with new spring etc.
Seems difficult to get any kind of info about Sthil.
/ Sthil FS45
Hi, I am pretty sure I have , I order a used starter housing on E b, waiting for it to arrive, it should match the end that is on the motor, Ill let you know the outcome.
Thanks for asking.
Geo🇺🇸
/ Sthil FS45
Hi, anyone know what Dia the starter rope is?
P/S runs like new, starts with 3 pulls.
/ Sthil FS45
Hi All, is there a good video to show how to replace the starter cord on an EZ start Stihl FS45 weed eater, to prevent the spring from unwinding?
1R CULTIVATOR, 3PT (A64280)
1R CULTIVATOR, 3PT...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
Frontier Quick Attach Pallet Forks (A64126)
Frontier Quick...
APPROX (50) 2" X 2" X 22" TUBING (18) 2" X 6" X 51 (A64280)
APPROX (50) 2" X...
2025 IR Electric Tricycle (A61574)
2025 IR Electric...
