Stepped off, and it almost tipped over (lifting a snowmobile) !
   / Stepped off, and it almost tipped over (lifting a snowmobile) !
There are some blocks (except for the small one's track, which I'll put a block under it when it's time to come down). Large gaps on the shelves lets light thru, and prevents more stuff getting piled on.
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #52
You should have welded up that sled shelf ... that wooden beam is going to sag. :laughing:
Cant weld anymore.:cool:
OK how far (in inches) does the TBN engineering squad estimate that the wood beam will sag? It's 5.75" x 7.5" x 242" long, Douglas fir.
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #54
.001 inches.. by my estimate.:D
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #55
Sodo you have bigger b-lls than me, if I felt it starting to go over I would have dropped snowmobile like a rock. I never would have stepped off and taken a picture. I have had BX on 3 wheels twice since I have owned it and Kioti never scared the crap out of me both times.
Thanks for picture
Scott
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #57
Thanks for picture
Scott
Only twice... you're not living!
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #59
Well DrZ, here it is, project finished. It's not a truck but similar. The chosen shelf height = 5ft 2" and the tractor can lift to 5ft 11".
And on to the other project, which was great fun. The hill doesn't look that steep in the pic, but to get a feeling for it - with ONE finger I was able to lift the ATV's left rear tire off the ground as it was parked there in the pic. As usual, some folks are quaking in their boots while the Russians nod off :zzz::zzz:
Excavator was just, great, great fun, chewing across the hillside - can't wait to get back to it! But the trail does go uphill, pretty significant uphill, it's not level as the pic looks. The trail is barely wider than the tracks, (4ft 3")
Nice shelf! I wanna do something similar for implement storage.
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #60
I sure hope the naysayers view this. As all can see from the photo, it is a long way from tipping over when the front axle hits the stops.
I have been trying to tell folks that the front axle does help in tipping situations but all I get is, "IT swivels and by the time it hits, it is too far gone" Well this photo proves that it isn't too far and the front axle definitely does help prevent a roll over. Putting ballast in the front tires would certainly help also.
I think the contention was that a roll started by a sidehill incline would not be stopped when the front axle reached its pivot limiters.
larry
UNUSED AGT SSECAG-Y HYD AUGER (A58376)
UNUSED AGT...
Flow Tech F15 Ball Valve With Gaskets SOLD 35x Times Money (A59213)
Flow Tech F15 Ball...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A58375)
UNUSED CFG...
2015 Caterpillar 305.5E2 CR (A57148)
2015 Caterpillar...
