Steering wheel tilt
/ Steering wheel tilt #1
ben21921
Elkton, Maryland
none/ yet
I've run into my first issue with my LS 3037 H I've had it for a little less than a year now and my wife uses it to cut the grass sometimes and she is a lot smaller than me so she tilts the steering wheel down. I got on it the other day and go to tilt steering wheel back up it won't lock anymore it just kind of floats up and down my question is is that an easy fix? And it should it be covered under warranty?
/ Steering wheel tilt #2
It is a friction lock, so there should be some sort of adjustment on it to increase the friction. You will need to remove some plastic?maybe metal in order to get to it though.
Ok, thanks for the info.
2012 Mack CHU613 Day Cab Truck, VIN # 1M1AN09Y6CM010558 (A65563)
2012 Mack CHU613...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2015 JLG G12-55A TELEHANDLER (A65643)
2015 JLG G12-55A...
LOOK! (A65640)
LOOK! (A65640)
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
