Steering problems
/ Steering problems #1
greene acres guy
Southern Michigan
John Deere 2305
I recently purchased a 2305 John Deere with R4 tires. I love this tractor , however when you turn all the way to the right the tires rub against the pin that releases the front mower deck. Anyone else have this problem, if so how can I remedy the problem. Any help would be appreciated. Greene Acres Guy
/ Steering problems #2
Can you reverse(side for side) the tires and solve the problem?
/ Steering problems #3
Is there a turn stop for the steering? On the Case and NH tractors they have an adjustable bolt that stops the steering so it can be adjusted not to hit FEL brackets etc. You might have something similar.
/ Steering problems
Thanks for the tip,I will check and see if there is an adjustment for that. A friend of mine told me the larger JD ag tractors have an adjustment for it.
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
2019 Terra Gator TG8400 Spreader (A63111)
2019 Terra Gator...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
