Steering problems
/ Steering problems #1
greene acres guy
Southern Michigan
John Deere 2305
I recently purchased a 2305 John Deere with R4 tires. I love this tractor , however when you turn all the way to the right the tires rub against the pin that releases the front mower deck. Anyone else have this problem, if so how can I remedy the problem. Any help would be appreciated. Greene Acres Guy
/ Steering problems #2
Can you reverse(side for side) the tires and solve the problem?
/ Steering problems #3
Is there a turn stop for the steering? On the Case and NH tractors they have an adjustable bolt that stops the steering so it can be adjusted not to hit FEL brackets etc. You might have something similar.
/ Steering problems
Thanks for the tip,I will check and see if there is an adjustment for that. A friend of mine told me the larger JD ag tractors have an adjustment for it.
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2011 Nissan Sentra Sedan (A61574)
2011 Nissan Sentra...
