Steering problem with JD650
/ Steering problem with JD650 #1
flytoboat
Southern Illinois
1981 JD 650
I am going to buy a 1981 JD 650 4WD from my Brother-in-Law. It has power steering and when you turn the steering wheel, the engine bogs down considerably. Also, the wheels turn much further to the left than they do to the right. Any body out there seen this problem and offer help? My search of the forums didn't turn up any thing like this.
TIA.
Don
/ Steering problem with JD650 #2
Check to make sure the hydraulic cylinder isn't bent, as well as any of the steering linkage. That's what it sounds like it could be anyway. I assum the lift works just fine, right? If so, that should be an indication that the hydraulic pump is working fine. One other thing that comes to mind is to see if you can verify that the hydraulic plumbing going to the power steering cylinder was done correctly. That may require a trip to a JD dealer, or maybe a look at the service manual. Let us know what you find.....
Tahnks for your response, KEBO. I'll try to check it out this weekend and let you know.
Don
(8) Massey Ferguson Tractor Suitcase Weights (A65640)
(8) Massey...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
TRUCK RAMPS (A64556)
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A65563)
2022 Ram 3500...
