Steering bracket/stripped threads
/ Steering bracket/stripped threads #1
Conservation
JD 1050 with power assist steering.
Bracket is attached to frame/block with long bolts, and I think spacers, although the spacers are nowhere to be found. There are other bolts holding on the bracket, so I didn't notice the steering right away.
The bolt holes seem to be stripped. Should I just get a large a__ed tap and go oversized after drilling? I have done all sorts of drilling and tapping, but never into a tractor block. The frame material is about 1/2" thick, and I suppose I could just thread that portion, or go with a Helicoil.
Any suggestions?
/ Steering bracket/stripped threads #2
The heli coil is the easiest way to go. I replaced threads in many blocks and heads in the engine rebuilding shop.
Thanks for the reply. I stopped at my friend's CarQuest, and he had what I think are called Tuffserts? Drill the hole, use the fastener with a stop nut on it, and the insert cuts its own threads. Wow! This was quicker, and the end product is much more robust than the Helicoils I have installed. Why the heck didn't I know about these before? Anyhow, drilling the holes just about wore me out! I have one insert in, and had to clean up to get to dinner with my wife tonight. I will finish up the job, which should last forever now. The only "bad" thing was that I had to switch to an english bolt since he didn't have the metric one, so those fasteners don't match the others. Big deal.
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
Unused 2024 Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024...
2012 COMPTANK ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK ACID...
CAT 973 GP Bucket (A68134)
CAT 973 GP Bucket...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
