Steering bracket/stripped threads
/ Steering bracket/stripped threads #1
Conservation
JD 1050 with power assist steering.
Bracket is attached to frame/block with long bolts, and I think spacers, although the spacers are nowhere to be found. There are other bolts holding on the bracket, so I didn't notice the steering right away.
The bolt holes seem to be stripped. Should I just get a large a__ed tap and go oversized after drilling? I have done all sorts of drilling and tapping, but never into a tractor block. The frame material is about 1/2" thick, and I suppose I could just thread that portion, or go with a Helicoil.
Any suggestions?
/ Steering bracket/stripped threads #2
The heli coil is the easiest way to go. I replaced threads in many blocks and heads in the engine rebuilding shop.
Thanks for the reply. I stopped at my friend's CarQuest, and he had what I think are called Tuffserts? Drill the hole, use the fastener with a stop nut on it, and the insert cuts its own threads. Wow! This was quicker, and the end product is much more robust than the Helicoils I have installed. Why the heck didn't I know about these before? Anyhow, drilling the holes just about wore me out! I have one insert in, and had to clean up to get to dinner with my wife tonight. I will finish up the job, which should last forever now. The only "bad" thing was that I had to switch to an english bolt since he didn't have the metric one, so those fasteners don't match the others. Big deal.
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
2004 JCB 8017 EXCAVATOR (A65053)
2004 JCB 8017...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
LEEBOY 8515B PAVER (A67714)
LEEBOY 8515B PAVER...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
