steel circular saw
   / steel circular saw #31
Here we go. The rage blades are rated for 4000rpm. If you have a 1" arbor, stick it in your chop saw and go. They don't have a 10" blade, an 8.25" will have to do.
Ian
   / steel circular saw #32
My experience with these carbide tipped metal cutting blades is that speed kills (the blade). A 14" abrase chop saw turns much too fast for these blades. The 14" carbide blades are designed to run at 1000 - 1450 RPM.
   / steel circular saw #34
I am going to be "that guy" - I bought the harbor freight metal cutting circular saw for about $60 with the metal cutting blade and it has worked great!!! Even cut some 1/2 plate (more than I think you are supposed to cut). used it for several projects and to be honest if it blew up tomorrow I can say I got my moneys worth out of it and would get another one. It was cheap especially with a blade although it is a bit ugly.......
ME TOO! cannot beat it for the money. Made lots of angle cuts on 1/4" x 4" flat stock and could not believe it. Great for the money but best bet to buy with 20% off coupon. I got my money out of it already!
   / steel circular saw #35
Even the blade that came with it has held up really well. I would have expected to had to replace it by now but it is still going strong!
   / steel circular saw #36
Got a Milwaukee metal saw here a while back. It's rated for up to 3/4" plate and so far has done a great job for me. The thickest thing I have cut so far was 1/2" AR 400. It went thru it about as easy as cutting plywood with a skil saw. Very handy tool to have for just over $300.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A55302)
2014 Doyle Dry...
2006 INTERNATIONAL 9200I DAYCAB (A55745)
2006 INTERNATIONAL...
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
