steel circular saw
   / steel circular saw #21
How about putting one of those blades in the chop saw? Would certainly have enough power and is probably built stouter than the average WW circular saw.
Ian
That is an interesting idea - not sure how fast the chop saw spins - maybe too fast????
   / steel circular saw #22
Chop saws are way to fast. at least by a factor of 2
James K0UA
   / steel circular saw #23
Also the published speeds for most of the worm drive saws seem to be in the 4400 rpm range, about 3 times faster than a cold saw.. Just like my vertical bandsaw, it is made for cutting wood and goes way to fast for metal even though metal blades are readily available for it.
   / steel circular saw #24
James K0UA
Just for curiosity's sake, I looked up a few saws on Lowe's site.
Dewalt chop saw 4000rpm
Skil direct drive circular saw 5600rpm
Skil worm drive circular saw 4600rpm
Harbor Freight metal cutting 7 1/4" circular saw 3500rpm.
Looks like a chop saw is not that bad of choice. It's a lot closer to the rpm of the metal saw than the others.
   / steel circular saw #25
I think the rage saws run 2500 rpm. 4000 is way high for that...
   / steel circular saw #26
I have a Rage 7 1/4" skill saw, and love it. The blades hold up, if you use it for what it is designed for. They can be resharpened. I did buy a Lenox blade for it, but haven't used it yet.
   / steel circular saw #27
Well I looked on rages web site and most of their 7 1/4 saws run at 2500 so I was wrong with the "factor of 2 statement" but still a chop saw at 4000 would be fast compared to 2500.. I was thinking they ran at 1500 like other cold saws but apparently not. I believe tho that as the blade gets larger you would need to run it at a slower rpm to maintain the samecut speed in surface feet per minute so a 14 inch cutoff saw blade if replaced with a 14 inch cold saw blade since it is larger would need to run that much slower. I do not think putting the cold saw blades in a machine not designed for them is a good idea.
James K0UA
   / steel circular saw #28
I picked up a speed reducer for the chop saw that I have not used since I bought the HF cold saw. When I locate a cheaper priced metal cutting blade I am going to give it a try. The likely issues are that the saw will not enough torque with the speed reduced. Anybody have a line on a cheap 12" metal cutting blade?:D
   / steel circular saw #29
Scroll to the bottom of this page for circular saw metal cutting blades:
Diablo Saw Blades 7
Bruce
   / steel circular saw #30
I looked into buying one of the Evolation Rage saws, just about pulled the trigger, then I thought why? I think that saw is a high production saw, and I'm not in that big of a hurry. I think you'd get more bang for your buck with a port a band.
I've read where a carpenter's skil saw turns too many rpms for the steel blades. Maybe you should just use an abrasive skil saw blade in your saw.
I'm with you--portable band saw. I have an $80 cheapie from Harbor Freight and use Milwaukee 24 teeth per inch blades at slow speed (the saw has a variable speed trigger control with lock button). Cuts 1/4" 4x4" tubing like butter.
2017 JLG T350 PORTABLE ELECTRIC MANLIFT (A52706)
2017 JLG T350...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
2003 INTERNATIONAL 9200I TANDEM AXLE DAY CAB (A56129)
2003 INTERNATIONAL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55302)
NEW HOLLAND 706 30...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
