steel circular saw
   / steel circular saw #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Well I have seen a few videos of saws like the Evolution rage circular saws, and I think something like that could be really useful. Well I dont have the spare cash for one of those, and I am not sure how long they would last. Now heres my question. We have an old 8 1/4 inch skill worm drive saw, and I was thinking of putting one of those metal blades on it. Would it work? Or would the saw be too fast or something? I am not worried about a fire, since the saw is all metal, and has only ever been used for masonary. I know the saw could stand up to it, but it is the blades I am not sure about.
   / steel circular saw #2
I never saw the commercials or heard of it before, so I went to youtube and watched this video. [ame=http://www.youtube.com/watch?v=uqirFDSOOaU]Rage Multi-purpose circular SAW @ www.tradecounterdirect.com - YouTube[/ame]
At first, I had my doubts, but seeing it cut through that C Channel impressed me!!!!
I wonder how long the blade lasts, but then looked on Amazon and saw that a new blade is only $40 and the whole saw sells for $142
[ame=http://www.amazon.com/Evolution-Power-Tools-Ragesaw-Circular/dp/B000WEKO0A]Amazon.com: Evolution Power Tools 7-1/4' Mp Hd Circ Saw Ragesaw Circular Saw: Home Improvement[/ame]
Sounds too good to be true. I wonder what I'm missing or how well it's built. I'm curious enough to join in here and ask if anybody has one or seen one in person?
Then I saw this blade and I'm wondering if this would be worth the money for my metal chop saw? [ame=http://www.amazon.com/Evolution-14BLADEST-Cutting-Steel-1500/dp/B001QF9VRG/ref=sr_1_10?s=hi&ie=UTF8&qid=1325953882&sr=1-10]Amazon.com: Evolution 14BLADEST 14 X 66T X 1 For Cutting Steel, Max RPM 1500: Home Improvement[/ame]
Eddie
   / steel circular saw #3
I looked into buying one of the Evolation Rage saws, just about pulled the trigger, then I thought why? I think that saw is a high production saw, and I'm not in that big of a hurry. I think you'd get more bang for your buck with a port a band.
I've read where a carpenter's skil saw turns too many rpms for the steel blades. Maybe you should just use an abrasive skil saw blade in your saw.
I am actaully getting a milwaukee abrasive chop saw within week or so. After having to make straight cuts in pipe with an angle grinder for my welding table, I saw just how useful they would be. (cant believe I didnt think to use my porta-band for it...) I was thinking of using the worm drive saw, because I think they spin slower then a normal saw. It is just sitting around collecting dust, so I thought I might as well put it to use. This is the saw I am talking about.
And shield arc, wouldnt your ellis bandsaw be more of a production machine then an evo chopsaw?
   / steel circular saw #6
The reason I bought the metal chop saw is that the gearing is lower for cutting metal and pavers. I also cut fake stone, real stone and bricks with it.
Seeing the video, I don't know why it wouldn't work in your saw. The blade is cheap enough and I bet your saw is more powerful and better built. I didn't like all the plastic on the saw in the video.
For $40, why not?
Eddie
For $40, why not?
Eddie
The only problem is I dont think the evo blades have the diamond shaped knockout in the middle, which you need for worm drive saws. I know lenox makes those blades, and I bet some of those have the knockout, but they cost a lot more. I think I have an abrasive wheel laying around for it somewhere, I will put it in, and see how it works.
   / steel circular saw #8
The Ellis is a fantastic saw for what it does. But for smaller items the Evolution Rage 3 will out work the Ellis. And the Rage 3 is a compound miter saw. But the Ellis will cut bigger items. For me, having the Ellis and a port a band and a chop saw I don't really need the Rage 3, but it would still be nice to have for aluminum work.
   / steel circular saw #9
deereman75
I 've used a carbide toothed chop saw .It was designed and built to cut steel ... don't think it was the evolution tho. The benifits of this type of saw for me was NO DUST.It was critical to keep the blade cool when cutting . The training facility I used it in disected welds to show new recruits imperfect welds and such.. like any blade it does not like jamming and lateral loads placed on it.
ak9
   / steel circular saw #10
I have been using carbide tipped 7 1/4" ferrous metal cutting blades in my model 77 Skilsaw for about 15 years. The blades will run $30-$70 each and can be sharpened just the same as any other carbide blade.
The biggest advantage is the portability. You get a clean, straight and burr free cut in material easily up to 1/2" thick.
Other advantages are, very few sparks (the steel is cut into little chips and not ground) almost no heat is created, there is no damage to painted surfaces.
You already own a good heavy duty saw that has all the power you need for cutting steel, just get a blade from Sears or Home Depot or just about anyone else that sells skilsaw blades. I like the ones that Makita makes but Dewalt, Diablo, Bosch and others make good blades also.
When you choose a blade for your saw make sure that it is rated at or above the the RPM level of your saw.
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
