Rod in Forfar
Platinum Member
- Joined
- Apr 10, 2010
- Messages
- 582
- Location
- Forfar, Ontario, Canada
- Tractor
- 1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
I saw this comment on another website and was wondering if it is true with all tractors.
Let it Idle
In cold weather, after your tractor has started, let it stand and run for a good 20 minutes. Adjust the idle up to around 1500-1700 RPM and just let it sit. The reason we do this is so that the heat of the engine dissapates into the transmission, transfer case and gear drives of the tractor. If we went to work right away, the gear oil is so thick that the hydraulics will not work and shifting gears is problematic.s when in cold weather.
On a recent cold day in Eastern Ontario I plugged in two tractors, a Kubota B7510 and a TAFE 351, using my new Kill-A-Watt to record the current consumed. 1 kw hour on the meter heated and started the two tractors. That can't be much over $.25, if that. Diesel has to cost more than that if used to warm up engines through idling.
(This morning was very cold, below -30C. I was happy for the 5W20 synthetic oil in my car when it started, first try.)
