Starting your tractor in the winter.
   / Starting your tractor in the winter. #181
Ok I have 3xx hours on my 2009 tractor and I have never used any kind of anything in my fuel, mostly use red #2 but occasionally use road diesel. I was never told to use anything in my fuel in the winter it is in the garage so I wasn't worried about gelling its always around 40 in there. Do you mean to tell me that I need something in my fuel for lubricant? What needs lubricated other than the engine oil? This is my first diesel so I am not stupid just dumb!:confused3:
   / Starting your tractor in the winter. #182
Here's one forum thread discussing upper cylinder lubricity:
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
If you google this query:
Diesel Engine upper cylinder lubricity
you'll get a number of links to read. Do take the advertising links with a grain of salt.
As I'd written in a previous post...I use Power Service.My tractor, a 2000 Deere 4400, is a bit older and I have read of Deeres of that generation having upper cylinder problems that have been attributed to ULSD.
Now, I'm sure this is not isolated to Deere...it's just I read more Deere threads then any other brand.
   / Starting your tractor in the winter. #183
Fuel pump lubricity is to minimize wear, and is a function of usage time. The fuel pump manufacturers felt strongly enough about it to demand a 460 mm 4 ball wear scar maximum, compared to API's 520 mm.
Now - when is the mean time to failure? I don't know, have not seen it. But I suspect it is meant for long use engine applications such as over-the-road class 8 truck diesels that last a million miles, not our little tractors that barely get a thousand or two hours (40mph avg x 1,000 hours ~ 40,000 miles per 1,000 hours run time). So, maybe it doesn't matter as much to us.
But - considering the fuel injection system is the most expensive part of any diesel engine by far, is it worth it to save 50 cents per fueling?
Not to me.
   / Starting your tractor in the winter. #184
I wasn't trying to save money, I am just ignorant to things diesel. Gas engines I got covered built, rebuild, torn down you name it, just don't know squat about diesels.
   / Starting your tractor in the winter. #185
Don't take forum responses too seriously...
TBN is a good place to learn some things about diesels, but you will get more opinion then fact...
   / Starting your tractor in the winter. #186
I wasn't. I don't take much too seriously anymore, like I said just diesel ignorant.
   / Starting your tractor in the winter. #187
Any idea why they would say on the link to their white bottle that it is only for temps below 30F? They just trying to sell the silver bottle?
If you are on their website, they have a FAQ tab as well. They say the white bottle is safe to use year round, but the silver bottle has more Cretans boost and more detergents.
If you don't need the anti gel properties of the white bottle, then the silver bottle is a better product. If you do need the white bottle, then it does have everything you need.
   / Starting your tractor in the winter. #188
They did - but - not enough per EMA (Engine Manufacturers) requirements. API spec'd 520mm 4 ball wear test max scar depth, EMA spec'd 460 per fuel injection pump manufacturers. So.......fuel suppliers aren't gonna add any more cost than they're required to, hence always use a lubricity supplement.
I'm guessing you meant to say "um" not "mm". 520mm is almost 2 '
   / Starting your tractor in the winter. #189
I think I'll use your advice on one of your own...:laughing:
All my engines- diesel, gas, propane... are brand name, well designed engines, and they rely on crankcase oil to lubricate the upper cylinder area.
That's why I don't need to buy snake oil additives.
Even a good older design uses crankcase oil to lubricate the upper cylinder
   / Starting your tractor in the winter. #190
Historically I used the silver but accidentally grabbed a white jug once last year and just stayed with it into the winter. I thought it odd the website conflicts with the labeling on the jug
Wacker Neuson G50 38KW (A56857)
Wacker Neuson G50...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2018 NISSAN Sentra (A56859)
2018 NISSAN Sentra...
2018 Chevy Silverado 1500 4X4 (A56435)
2018 Chevy...
