Starting your tractor in the winter.
   / Starting your tractor in the winter. #171
I like to purchase my diesel where the towns/cites power companies etc. fuel up,station has winter diesel cut plus fresher supply.
   / Starting your tractor in the winter. #172
I try not to use the 911, it's not great for the engine. It contains alcohol. I do use power service with anti-gel (white bottle) as it's easy to get. I often use it year round simply because I have treated fuel left over from winter that lasts well into the summer. I don't think there's any difference between the silver bottle and white bottle except for the anti-gel. There are other brands that do work better (lubricating, not anti-gel) if you are willing to spend more.
   / Starting your tractor in the winter. #173
Any idea why they would say on the link to their white bottle that it is only for temps below 30F? They just trying to sell the silver bottle?
   / Starting your tractor in the winter. #174
Why would you need any additive for temps above 30 degrees?
   / Starting your tractor in the winter. #175
   / Starting your tractor in the winter. #176
Mostly for lubrication with the ULSD fuel.
I'd ask why doesn't No. 2 diesel come with enough lubricity already in it. But I can guess that the answer is some dumb government regulation written by a tree hugger bureaucrat that knows absolutely nothing about diesel engines. :rolleyes:
   / Starting your tractor in the winter. #177
That's what the sulfur was for. Now, as to why they haven't included a suitable substitute in pump fuel...:confused3:
   / Starting your tractor in the winter. #178
And you're right...the problem is more with older tractors. I use Power Service every time I fill the tank.
   / Starting your tractor in the winter. #180
They did - but - not enough per EMA (Engine Manufacturers) requirements. API spec'd 520mm 4 ball wear test max scar depth, EMA spec'd 460 per fuel injection pump manufacturers. So.......fuel suppliers aren't gonna add any more cost than they're required to, hence always use a lubricity supplement.
Also, most commercial diesel fuels have min. cetane (40) where our small engines require 50. So need cetane booster too to get complete combustion - prevents exessive deposits on injector nozzle tips, etc.
I use Opti-Lube XPD. No alcohol.
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
More info coming soon! (A55851)
More info coming...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
