Starting your tractor in the winter.
   / Starting your tractor in the winter. #171
I like to purchase my diesel where the towns/cites power companies etc. fuel up,station has winter diesel cut plus fresher supply.
   / Starting your tractor in the winter. #172
I try not to use the 911, it's not great for the engine. It contains alcohol. I do use power service with anti-gel (white bottle) as it's easy to get. I often use it year round simply because I have treated fuel left over from winter that lasts well into the summer. I don't think there's any difference between the silver bottle and white bottle except for the anti-gel. There are other brands that do work better (lubricating, not anti-gel) if you are willing to spend more.
   / Starting your tractor in the winter. #173
Any idea why they would say on the link to their white bottle that it is only for temps below 30F? They just trying to sell the silver bottle?
   / Starting your tractor in the winter. #174
Why would you need any additive for temps above 30 degrees?
   / Starting your tractor in the winter. #175
   / Starting your tractor in the winter. #176
Mostly for lubrication with the ULSD fuel.
I'd ask why doesn't No. 2 diesel come with enough lubricity already in it. But I can guess that the answer is some dumb government regulation written by a tree hugger bureaucrat that knows absolutely nothing about diesel engines. :rolleyes:
   / Starting your tractor in the winter. #177
That's what the sulfur was for. Now, as to why they haven't included a suitable substitute in pump fuel...:confused3:
   / Starting your tractor in the winter. #178
And you're right...the problem is more with older tractors. I use Power Service every time I fill the tank.
   / Starting your tractor in the winter. #180
They did - but - not enough per EMA (Engine Manufacturers) requirements. API spec'd 520mm 4 ball wear test max scar depth, EMA spec'd 460 per fuel injection pump manufacturers. So.......fuel suppliers aren't gonna add any more cost than they're required to, hence always use a lubricity supplement.
Also, most commercial diesel fuels have min. cetane (40) where our small engines require 50. So need cetane booster too to get complete combustion - prevents exessive deposits on injector nozzle tips, etc.
I use Opti-Lube XPD. No alcohol.
2007 MACK CV713 ROLL OFF TRUCK (A58017)
2007 MACK CV713...
2022 INTERNATIONAL MV607 (A58214)
2022 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
1994 SUNDOWNER 4 HORSE GOOSENECK TRAILER (A52708)
1994 SUNDOWNER 4...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
