Starting your tractor in the winter.
   / Starting your tractor in the winter. #161
Even though my tractor was plugged in all night at ten below this morning it wouldn't run right. Spent the whole day getting it right. Local mom and pop store has diesel so gelled up they can't pump it. I had at least ten gallons of their fuel in the tank. Your block heater doesn't do anything to keep the fuel in the tank warm. When taking off the fuel filter to flush it with diesel 911, I found I wasn't even getting fuel from the tank to the filter hense the problem. I ended up putting a drop light right under the bottom of the tank where the fuel line leaves to thaw it out. Once I had fuel to the filter and did the bleeding process it started right up.
I'm surprised the Ma and Pa shop didn't have winterized diesel.
Glad you got your tractor started!
Did you get what you needed from Trottier's?
   / Starting your tractor in the winter. #162
Is the info in this thread accurate? My question concerns glow plugs heating the air in the combustion chamber. That is not what the major glow plug suppliers say they do. They say that one turn of the engine expels any heated air. Manifold heaters do supply heated air, but glow plug suppliers talk about their glow plugs provide a hot spot to ignite the fuel/air mixture when compression alone does not raise the air temperature enough. I am not sure if the chart I gave tried to attach will show but it is Bosch's glow plug heating chart showing how their glow plug heats to maximum temperature in about 4 - 5 seconds and then drops off a bit but always stays well above the temperature needed to ignite a diesel/air mixture. The reason for the drop off is if the glow plug remains heating at the maximum rate it will quickly burn out so modern high quality glow plugs automatically drop current flow once maximum heat is obtained.
This is the glow plug type we used on our small (less than 7 liter) Cat engines when we changed from the manifold heater to glow plugs with Tier 3. Maybe the Asian suppliers have a different technology but when you think of the heated air being exhausted before it even gets a chance to be used in an injection cycle it is difficult to understand.
Grid heaters and fuel fired manifold heaters do heat the incoming air but I have not seen a glow plug supplier claiming they heat the air. I have, however, seen the glow plug suppliers talk about rapid heating to provide the ignition point. In fact the best (also most expensive) Bosch and BERU glow plugs heat so fast they claim you can just start your car like normal. The plugs will do their job by the time the engine cranks over.
So a, I totally mistaken and Asian tractor glow plugs work differently than American and European diesels?
https://www.google.com/url?sa=i&rct...vI2G2HRjhBikBeZZ0oxl7h7Q&ust=1387176228495384
   / Starting your tractor in the winter. #163
Roy Jackson;
Yes they fixed me right up on the scv fitting and diesel 911 but I should have bought a fuel filter while I was there and didn't think of it. I need another gallon of Hyguard so will pick it up when I stop to get that.
   / Starting your tractor in the winter. #164
WOW! This is some revelation! What say you, fellow Tractorbyneters?
   / Starting your tractor in the winter. #165
tractor_glow_plugs.jpghttps://encrypted-tbn0.gstatic.com/...mkYGx9adYjKpFXgzA9FKN-ALao-Xo241nWurCoJNo6zsn
The attached picture shows several different diesel cold start aids. On the right is the type of manifold heater used by older Perkins, Allis-Chalmers, and other engines. They have a heating coil that both opens a fuel orifice that sprays fuel into the intake manifold where it is ignited by that same heating coil. This type has been used on lots of different brand large commercial diesels. It is difficult to control emissions properly so now other heater types are used such as the grid manifold heaters. Both the fuel fired and grid heaters heat the combustion air.
Glow plugs do heat air but the air is that immediately surrounding the glow plug during each compression stroke. Glow plugs are optimized for either indirect injection or direct injection. Remember that the Diesel cycle differs from the Otto (gasoline engine cycle). Diesels ingest a full cylinder of fresh air with each stroke - needed for the compression to get the air up to ignition temp. Then only enough diesel fuel is injected. The glow plugs are in this stream so they can heat the small amount of air where some of the fuel is sprayed starting the flame front.
If you read up on glow plug history from the different manufacturers you will see that a problem with older designs is that people tend to overuse the glow plug (turn it on for an excessive period of time) which results in burned out glow plugs. The newest (probably meaning most expensive designs) are self controlling.
Watch the attached glow plug video to see how the tip heats. The air heated immediately surrounding the glowing tip is enough to start the fire.
DieselRx Glow Plug Comparison - YouTube
   / Starting your tractor in the winter. #166
I had a 1985 6.2 GMC. It was a poor starter. I hot wired in a starter solenoid and manually kicked in the glow plugs a few more seconds and that sure helped. But I heard (after burning them out) that because GMC wanted them to start easier they actually used 6 volt plugs and used a thermostat on them to prevent burning them out. But they were worthless. It had to be plugged in below 20 degrees or it might not go.
   / Starting your tractor in the winter. #167
If you have any Irving stations near you I suggest buying your fuel from there, all of their diesel is refined for winter use.
   / Starting your tractor in the winter. #169
Be carefull on that assumption. In some cases it may be the nearest refinery or one that has a supply.:D
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
NEW HOLLAND 105 WORKMASTER MFWD TRACTOR (A52708)
NEW HOLLAND 105...
2018 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP6JFD27162, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2018 Ford F-150...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
