def38
Platinum Member
I would also take off where the negative cable connects to the frame and clean that up and then reattach it with the negative cable from the battery on the bottom so that it is the closest to the frame with the smaller terminals on top of it. That should give you the best possible connection for your negative terminal.
Aaron Z
The negative battery cable shown in the photo uses a crimped eye terminal at the chassis end and a crimped battery post clamp at the battery end. The cable connections cannot be swapped.
BTW, that new battery is way oversized for the application.
