Starting Issue - Kubota B8200
   / Starting Issue - Kubota B8200 #11
I would also take off where the negative cable connects to the frame and clean that up and then reattach it with the negative cable from the battery on the bottom so that it is the closest to the frame with the smaller terminals on top of it. That should give you the best possible connection for your negative terminal.
Aaron Z
The negative battery cable shown in the photo uses a crimped eye terminal at the chassis end and a crimped battery post clamp at the battery end. The cable connections cannot be swapped.
BTW, that new battery is way oversized for the application.
   / Starting Issue - Kubota B8200 #12
As soon as I disconnect the jumper cables, all the lights and gauges go dead. Tractor still runs fine but no electric features work.
I believe that suggest you have an electrical problem.
Start by checking all the connections at the battery and measure the voltage at the battery with the engine running fast idle. Report back.
   / Starting Issue - Kubota B8200 #13
You are misunderstanding me. I am saying, remove the bolt that holds the negative cable to the frame, clean around the hole and put it back together.
Aaron Z
You all are amazing. Thank you for taking your time to help me out. I will follow up as soon as she fires up! I have a lot of great suggestions to troubleshoot.
Are you guys sitting down? This is probably the most stupid mistake of my tractor life. I can't thank you all enough for helping me troubleshoot. I learned a lot. I especially learned how stupid I am. :duh:
Just remember when you're having trouble with your tractor and realize it's something simple, just say, "Well at least I'm not as mentally challenged as that guy who left the cap on his negative terminal."
   / Starting Issue - Kubota B8200 #17
The cap was left on the negative terminal. View attachment 605246
Not the first time and won't be the last... Sorry I didn't catch that. Now that I look, I see that in your first picture...
Aaron Z
   / Starting Issue - Kubota B8200 #18
Don't beat yourself up too much....we missed it too. At least you now have a huge, new, reliable battery.
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Allied 760 Loader (A50515)
Allied 760 Loader...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
CATERPILLAR 259D3 SKID STEER (A51242)
CATERPILLAR 259D3...
