starting/Fuel injector pump Problems
/ starting/Fuel injector pump Problems #1
leomech
Clanton, Alabama
Yanmar YM-1601D
YM-1601D When it started it would run wide open, I would quickly decompress. Found grit in the filter bowl. went looking further down stream at the injector pump took off the injector lines and then the nuts on the injector pump housing that have the springs and valve pieces, Did not remove the pump it self. Found #1 (closest to the fire wall) stuck at the top of its cycle . Got the grit out, all three valves are moving up and down. When all back togather clean fuel, new fuel filter bled system and only #3 is squirting fuel. Asked a John Deere mechanic about it he said the timming is messed up I did not take the pump off and I belive all parts are in order. Any help on this will be most appreciated. Leo
/ starting/Fuel injector pump Problems #2
Tell the JD mechanic that the timing can only be affected by removing the pump and adding or losing shims. Are all 3 pistons still moving up and down? If grit got past the filter you could very well have pump AND injector problems requiring professional cleaning.
Thanks for the reply That didn't sound right to me about the timming. But still have a problem.
/ starting/Fuel injector pump Problems #4
Leo, nothing to do with your problem, but do you really have a ym1691d? I have never heard of one. I believe I might check the plungers again. May be hung again with some of the grit.
1601D Not having a manual isn't helping I have a blowup of the pump going to recheck assy. and for something being stuck. Thanks again.
/ starting/Fuel injector pump Problems #6
It is likely that you still have a little air in the lines. Could your JD guy have been asking about the shims used to set timing on some small Yanmars. What engine do you have?
/ starting/Fuel injector pump Problems #7
leomech,I've got a 1610d,you can't get a manual for it but can get one for the nearest US model which is YM226&226D.I got mine from Sheaffer's,ph.#815-284-3226.also got a parts CD for the 1610d that's in jap. but is pretty easy to figure out because it shows the parts and numbers.I got that from Wayne who posts often on this site.the manual for the 226d is real close to the 1610d and was real helpful to me when I put in a new Headgasket and some other repairs. russ
/ starting/Fuel injector pump Problems #8
kjung17,he should have 3t75u engine in his 1610d russ
Thanks for all the info, I went into the pump some more found more grit as suppected also the thin copper packing under the bottom plunger is damaged
item 14 in the pump picture that I can't seem to post.
Yanmar Tractor Parts: INJECTION_PUMP
Up and running, The engineer in me said those little shims won't keep me from running. It started so quickly it startled me. I will replace the packings but for $1.05 I won't let that slow me down. Thanks for All your input and spell check!.
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2016 Ford Explorer 4WD SUV (A61569)
2016 Ford Explorer...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
