starting fluid ruins glowplugs?
/ starting fluid ruins glowplugs? #1
corelokt308win
I was getting a car inspected today and was talking with the mechanic about various mechanical problems I've had of late, and the Iseki glowplugs came up. He says starting fluid will ruin glowplugs, even after only one use. Is this so?
/ starting fluid ruins glowplugs? #2
</font><font color="blue" class="small">( I was getting a car inspected today and was talking with the mechanic about various mechanical problems I've had of late, and the Iseki glowplugs came up. He says starting fluid will ruin glowplugs, even after only one use. Is this so? )</font>
I was under the impression the problem was more along the lines of spraying starting fluid on hot glow plugs will ruin YOUR day...
/ starting fluid ruins glowplugs? #3
Don't know about your brand but Mitsubishi and Satoh diesel engines will not tolerate starting fluid. The piston tops are too thin. They use glow plugs. You should go to satohparts.com and look at the pictures of an engine damaged by ether. I know that some engines will take ether. We used it all the time on our farm tractors when I was growing up. However, constant use of ether will cause your engine to become addicted to it. This is because the additional volatility of the ether eventually rounds off the top of the piston rings. I don't know about whether ether will damage the glow plugs. If it won't start using the glow plugs you may want to make sure the glow plugs are working like the should. May also want to consider a block heater.
/ starting fluid ruins glowplugs? #4
Under no circumstance use either in a glow plug engine. That is the fastest way to destroying your engine.
FRAME FOR 3PT SCRAPE BLADE (A60430)
FRAME FOR 3PT...
2020 CATERPILLAR 279D3 SKID STEER (A60429)
2020 CATERPILLAR...
2003 PETERBILT PB330 DUMP TRUCK (A60430)
2003 PETERBILT...
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
(18) 10'-6" PVC CONDUIT PIPES (A60432)
(18) 10'-6" PVC...
