Starting and Running w/o battery installed
   / Starting and Running w/o battery installed #11
Shouldn't be any issues...
Once did a whole days snow blowing with a dead battery; ran fine till I shut it off and would only click.
Just tape up your positive lead
   / Starting and Running w/o battery installed #12
I wouldn't say having a dead battery installed is the same as no battery. In a cheap lawnmower then fine. In an expensive tractor that gets more high tech every day I wouldn't try it. They no longer condone it in cars because of the electronics, why chance it in a tractor.
   / Starting and Running w/o battery installed #13
A dead or under charged battery is hard on the charging system.
   / Starting and Running w/o battery installed #14
The OP may be able to clear this up; how long are you going to run it?
Not much electronics in a Bseries Kubota!
   / Starting and Running w/o battery installed #15
the battery need to be there even if shes dead she take care of the voltage
   / Starting and Running w/o battery installed #16
keep your battery there even if she dead she take care of the voltage
   / Starting and Running w/o battery installed #17
You need 12v to stop the engine with the key via the stop solenoid so its a crap shoot if it will shut down same with the safety circuit might not work correctly.
tom
   / Starting and Running w/o battery installed #18
tom
I think you supply VDC to the fuel solenoid and leave energized to run, and remove VDC to stop. Should not have to apply VDC to stop. Philip.
   / Starting and Running w/o battery installed #19
I have heard that on the bxs if the fuse blows they will not shut off.
   / Starting and Running w/o battery installed #20
My BX and GR will not shut off without 12V power. The alternator _may_ be able to activate the shut-off solenoid long enough. Don't know.
A _missing_ battery can allow voltage spikes that can damage the alternator diodes and other electronics - or could with older systems.
On the boat we use a device called a "zap stop" to avoid alternator damage if ones idiot brother-in-law switched the battery switch to OFF while the engine was running. It's a big Zener diode that clips the spikes.
Something like that might help in a no battery situation, but far easier to just leave it connected until replaced.
Z.
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2012 GMC SAVANA BOX TRUCK (A51243)
2012 GMC SAVANA...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
John Deere 693 Corn Head (A50514)
John Deere 693...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
