Starting and Running w/o battery installed
   / Starting and Running w/o battery installed #11
Shouldn't be any issues...
Once did a whole days snow blowing with a dead battery; ran fine till I shut it off and would only click.
Just tape up your positive lead
   / Starting and Running w/o battery installed #12
I wouldn't say having a dead battery installed is the same as no battery. In a cheap lawnmower then fine. In an expensive tractor that gets more high tech every day I wouldn't try it. They no longer condone it in cars because of the electronics, why chance it in a tractor.
   / Starting and Running w/o battery installed #13
A dead or under charged battery is hard on the charging system.
   / Starting and Running w/o battery installed #14
The OP may be able to clear this up; how long are you going to run it?
Not much electronics in a Bseries Kubota!
   / Starting and Running w/o battery installed #15
the battery need to be there even if shes dead she take care of the voltage
   / Starting and Running w/o battery installed #16
keep your battery there even if she dead she take care of the voltage
   / Starting and Running w/o battery installed #17
You need 12v to stop the engine with the key via the stop solenoid so its a crap shoot if it will shut down same with the safety circuit might not work correctly.
tom
   / Starting and Running w/o battery installed #18
tom
I think you supply VDC to the fuel solenoid and leave energized to run, and remove VDC to stop. Should not have to apply VDC to stop. Philip.
   / Starting and Running w/o battery installed #19
I have heard that on the bxs if the fuse blows they will not shut off.
   / Starting and Running w/o battery installed #20
My BX and GR will not shut off without 12V power. The alternator _may_ be able to activate the shut-off solenoid long enough. Don't know.
A _missing_ battery can allow voltage spikes that can damage the alternator diodes and other electronics - or could with older systems.
On the boat we use a device called a "zap stop" to avoid alternator damage if ones idiot brother-in-law switched the battery switch to OFF while the engine was running. It's a big Zener diode that clips the spikes.
Something like that might help in a no battery situation, but far easier to just leave it connected until replaced.
Z.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Payment Instructions (A47384)
Payment...
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
14 Ft Yellow Trailer (A50324)
14 Ft Yellow...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
