Starting a tractor in extreme cold temperatures
   / Starting a tractor in extreme cold temperatures #82
When we lived in Alaska - lower radiator hose tank heaters were the only thing we ever used. YES - they do circulate the water. When operating they will sound very much like an old percolator coffee pot.
   / Starting a tractor in extreme cold temperatures #83
Typically, that's what's used in generators too, at least the ones I'm responsible for. Heater isn't in the radiator hose, it seems to be a specially plumbed line that utilizes heater lines (many generators use auto engines). They're quite effective.
   / Starting a tractor in extreme cold temperatures #84
So for two weekends in a row, I was unable to start the tractor with temperature around -35C. Had to wait for the temperature to be a 'mild' -20C for it to start.
I have a 300W heater on the cooling line and installed last weekend a battery tender. The heater is turned on for about two to three hours prior to the attempts at starting it. The tender stays 24/7.
What I do is 4 cycles of 8 seconds glow plug and try to start it. At first, because of the battery tender, it turns pretty good but fails to start. Grey smoke comes out but that's it. I do a few more cycles of the glow plugs and it still fails to start. I crank for about 5 seconds each time. After about 5 or 6 attempts, battery is having difficulty turning the engine so I stop and let the temperature warm up. At -20C, after about 3 cycles of the glow plugs, the engine fires no problem.
What's the trick to start a diesel engine in such extreme temperatures?
Thanks
Something you might want to try: Amazon has a variety of Electric Dipstick heaters that slide in where your oil dipstick goes. Just plug it in and it transfers heat straight to the oil itself. Will help to thin that really thick oil somewhat. That and a good block heater right in the block should get you going.
   / Starting a tractor in extreme cold temperatures #85
This:
Radiator Hose Heater 1-1/4" 600 Watt
Is the style of lower radiator hose heater I was referring to. There is no "circulation" happening inside the heater unit. It is only a heater element that "wraps" around the coolant passage.
I think THIS:
Circulating Coolant Heater 1000 Watt 120 Volt
This must be the type of heater you are referring to? I have never seen one of these in the field. Never knew THIS style existed until I just now searched for it.
What the OP (and I) have been referring to is the first one. The heater that goes in the line of the lower radiator hose. My description of how this type heater works stands.
I just had this exact circulating coolant heater installed on my gas IH 656. Several days ago it was 15°F below zero and I plug this in for about three hours. Initially only the outflow coolant line was warm but after three hours not only was the output and input line warm but the entire block was warm. It clearly circulated throughout the engine. While not a diesel, it certainly fired up very quickly. It undoubtedly circulates since there is no other way the entire block would be warm if it didn’t
   / Starting a tractor in extreme cold temperatures #86
Move to Florida, sorry couldn’t resist
   / Starting a tractor in extreme cold temperatures #87
The dipstick heater is worthless at -35C
   / Starting a tractor in extreme cold temperatures #88
Glow it longer by alot and dont give up cracking it. Just getting the engine turning and the plugs hot are taking alot of power.
Won't that be hard on the starter?
  • Good Post
Reactions: JWR
   / Starting a tractor in extreme cold temperatures #90
I can't. The glow plug light will automatically turn off after 8 seconds, even when manually switched to the Glow position. It's a 2010 Kioti LK30.
I think you must wait 30 seconds between glow plug cycles for the computer to reset.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
