Starting a Garden
/ Starting a Garden #1
podagrower
Eustis, FL
NH TC 40
Next spring, I intend to start my first garden. Like a lot of people, we had a garden when I was growing up, but it was left behind as lives got busier. Now that I have a tractor and some acreage, I want to grow something. I have an area about 1/4 acre just begging to grow some food in.
Where I live is mostly sand, so I am going to bring in a few inches of top soil/muck/poo to richen up the soil. I have water nearby, so that should be easy to finish.
My questions for you guys are
1. Tiller versus disc
2. How to irrigate (I would like to use a drip system, but that would have to be removed each year for discing/tilling)
3. Seed dispersment (PVC pipe and funnel, fancy seeder)
4. Any crops that are a gaurenteed disaster for a first time gardner
/ Starting a Garden #2
1. The tiller costs more, but it'll produce a much better seed bed
2. Most of the folks I knew used sprinklers and/or soaker hoses. I had the time, so I hand watered with a wand.
3. Depends on what you're planting. For the onion sets, I simply made a trench with a hoe, laid the onion sets in place then pulled the dirt back around them with my hands. Tomato plants were set individually using a little hand trowel. But for seed, planted in rows, the Earthway Precision Planter was quite handy. Before that, I made a trench with a hoe, dropped the seeds manually, then pulled the dirt over the seed with a garden rake.
4. Not if you have the right soil, right ph, right nutrients, right climate, right amount of water, plant at the right time, and don't have too many crows, insects, and/or plant diseases.;)
/ Starting a Garden #3
My parents have had a garden since before I can remember. For the past many years they have constructed raised beds for a couple of reasons:
1. Doesn't require annual tilling since the ground never gets compacted (don't walk in the raised beds).
2. Allows drip watering to be installed year-round. In our colder climate we blow out hoses/pipes after harvest.
3. Provides a bit better definition of each section.
4. Requires a bit less bending...
Good luck!
Mike
/ Starting a Garden #4
Fl. and here is two different animals as far as garden raising.
Yeah,get you a tiller for your tractor,I got a 5 ft one for a 30 hp tractor.
Easiest way to start probably is furrows from one end to other end,than you'll need a walk behind tiller to weed and bring up loose dirt to hoe,[go between rows].
You'll no doubt have to have a good fence of some sort to keep at least some critters out[here is deer that probably does most damage].
And if its poor soil,you won't have much luck,so.
Watering,I let god water mine,always grow a descent garden in the water regard,but we can't water,just have a well,and I'd rather have water for us than garden. But if you can,yeah set up something,sprinklers would be easiest.
And just follow seed package directions. You'll know more next year.
/ Starting a Garden #5
Good luck!
Mike
Raised beds are my preference as well. Why, single biggest reason is WEEDS! If I had to go back to weeding, I'd quit gardening, which I shall never do. I use cardboard between plants and put mulch that will deteriate over it..
I'm just now doing the drip water thing and it seems to be the cats meow.. Rather easy to do..
And of course, with all the compost, I can stick my hand into the soil about 8" and my tiller is now useless and sits idle for the past few years. Have 15 boxes 4'x8' and if I did it over, they'd be 3 1/2'x8'
/ Starting a Garden #8
Why next spring???? If you have the disc chew it up every which way until good and lose. Hill it, throw some 10-10-10 on it and plant some beans, carrots, or what ever. Get it ready for a good fall crop and then into a winter crop. Here in Fl. there are four planting seasons and crops. Check with locals to find what to grow when.
Irrigation is tough! I had 1" of rain the first 2 1/2 months of this year. Then I had 10-12" in the last few weeks! Try and deal with that!
Raised beds are great but not for a 1/4 acre.
/ Starting a Garden #9
I agree that you need to just get started now the best you can. If you only grow tomatos and cucumbers this year, at least you got fresh tomatos and cucumbers to can pickles for later.
1/4 acre isn't that big a garden by the time you plant a few of the things you want.
With sandy soil, you probably don't need a big tiller to break ground. I wonder what maintenance issues there are from using tillers in sandy soil? Some of your local gardeners can probably give you good advice.
/ Starting a Garden #10
If you are going to wait until next year to plant and use this year to improve the soil get a soil test done by your county extension agent. It really helps to know what the soil needs and allows you to incorporate it deeply into the soil for better end results. Waiting would also let you grow a cover crop now and during the winter to add organics to the soil.
MarkV
/ Starting a Garden #11
MarkV
I agree with this a lot, tilling this year planing an over crop to help condition the soil for next year is also wise. but the crop may depend on what the soil needs, sandy may need lots of add on stuff... You may even want to till multiple times this year adding different materials as you go to help next years crops.
that all being said beans, taters, peas & the like can usually grow in about anything. They will also help most soils if simply left to grow & till in add in some clover and or other quick growing cover as well.
mark M
/ Starting a Garden
Thanks for the input so far. I'm glad Bird had the crop disaster assesment sorted out for me;). I'd love to start this year, and have debated fertilizing the snot out of it and putting in some seed, but I have to wait for my topsoil.
/ Starting a Garden #13
I've had a garden in somewhat sandy soil for about 5 years now. This last year hubby had to add a lot of fill it had sank. Also he limed and feritilized it and disced it in. I think I still need to sidedress it as its been a few months but I know its helped.
/ Starting a Garden #14
Ok, sandy soil. Sounds like mine. :)
When I started mine, I found out the city of Tulsa gives mulch away free made from trees/limbs chopped up. I had two 18 yard dump trucks bring it to me. They charged me about 125.00 per load. Maybe you have a place that gives it away as well and you could till it in and by next year have a nice spot.
The price to be paid is the ants you import with it.. :)
Also, if you get in a hurry, around here, there is a place called Gem Dirt. They sell leaf compost cheap by the yard.
Just giving you ideas..
/ Starting a Garden #15
picked my first garden goodies... the first asparagus was picked today... about 10 or so spears half of them as big around as my thumb
/ Starting a Garden #16
I have used city mulch on my flower beds in the past, but be aware that they grind up a lot of trees that are rotten, have termites and may be covered in poison ivy plus a lot of other mystery material. If they compost it well, it helps get rid of some of the undesirable stuff, but it may not be possible to tell what you're getting in city mulch. Your city may do a better job of screening material than ours did.
I think you'll be pleasantly surprised if you'll plant just a little bit of the usual garden veggies even if you don't plant the whole garden.
/ Starting a Garden #17
Two days ago picked a mess of green beans. I was surprised, that's early even for us. My second cutting of spinach, third of lettuce. The radishes are gone, been eatin' on the onions for awhile now, have Texas Sweets and they are good. Also got 2 ripe cherry tomatoes today, they were delicious.
I think I'm going to be canning green beans in about a week and I'm not ready. Still working on the house so I'm pooped, but gotta do it if they come off.
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
240156 (A56859)
240156 (A56859)
