Starter on Carroro 68.4
   / Starter on Carroro 68.4
   / Starter on Carroro 68.4 #72
Most likely one like this.
HELLA 8EA 015 642-651 Démarreur - 12V - 3kW - pour p.e. PERKINS Amazon.fr
Most starters I've seen for this engine are not gear reduction type
Ok cool i'll have a look . I've found out one of the sleeves is leaking so might have to replace . New one is around 23 euros , i've seen a trick where someone gets a small screw driver and hammers down along the sleeve but to put a new one in it's freezing it but how cold does it have to be to just slip in ?
Ok right night , i thought i would try it again with the cylinders and so i put vinegar in them , and for some reason all but one stayed full . does that mean theyre all right after all ?
   / Starter on Carroro 68.4 #75
Not sure why you would use vinegar and why 3 of 4 don't leak. Unless the cylinder has a hole/crack, it should not leak. It also shouldn't move, but it is kept in place by the head.
i used vinegar cause i didn't have diesel and didn't want to use water , there not holes or cracks .
2017 Ford F-550 (A55973)
2017 Ford F-550...
Brent 320 Auger Wagon (A59814)
Brent 320 Auger...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
Nissan Forklift (A55973)
Nissan Forklift...
JCB 3C 15' BACKHOE (A60429)
JCB 3C 15' BACKHOE...
