Starter not getting full voltage
/ Starter not getting full voltage #1
Liltote
1949 Ford 8n
Good afternoon all. I have a 1949 Ford 8n 6v. It is turning over slowly, when i test the starter, i have 6.35v on the battery side, and when i activate the starter i only get 4.3v on the starter side. Does anyone have any ideas on this? Thanks for your help.
/ Starter not getting full voltage #2
It could be a bad cell in the battery, check the voltage at the battery terminals when engaging the starter. If it drops, bad cell. If it stays at 6+v, check the connections at the terminals, starter connections, and solenoid, if separate, and ground. Take note of the cable condition as well; if the clamp has lots of corrosion and the plastic jacket has swelled near it, the corrosion has migrated down the cable and is causing lots of resistance.
/ Starter not getting full voltage #4
As said above, condition of battery, cables, and connections. Over the years many things get changed. Sometimes the correct parts aren't used. A prime example is using 12V battery cables on 6V systems. Number 2 copper should be the minimum, with 0 or 00 preferred.
/ Starter not getting full voltage #5
Replace both cables and load test battery. A 12V system sees nearly the same percentage of voltage drop when starter is powered, but with 6V the starter needs all the voltage/amperage it can get.
/ Starter not getting full voltage #6
If you don't find a flaw in the starter cable or the ground, or any of the connections, I would have the battery load-tested, many if not most auto parts stores will do it free.
You might also try an 8 volt battery. Most old charging systems will keep them at 8+ volts. That's what I had to do on the old Cub in the avatar.
/ Starter not getting full voltage #7
Years ago I had the same problem and couldn't find the issue.
Early one morning I was starting the motor and saw sparking where the throttle cable came though the firewall. Never figured what the original problem was but I attached a new ground cable from the engine to the frame and the problem went away and it stopped sparking where the throttle cable went through the firewall.
/ Starter not getting full voltage #8
I've read about mechanics troubleshooting electrical problems by turning out the lights and looking around. I personally haven't found a short by doing that though!
/ Starter not getting full voltage #9
At that age I would pull both battery cables and inspect them carefully. If all is well clean the block where the ground connects to the engine and treat it wit a good antioxidant grease. Treat all if the terminals and reinstall. If that doesn’t help I would test the draw on the starter. This is the reverse of my typical troubleshooting steps but a tractor that age will most likely benefit greatly from the attention.
/ Starter not getting full voltage #10
Personally I would convert it to 12 v . Easy enough to do I converted my 900 Ford and have no regrets! Starts easer especially in the winter. Just remember to replace coil with 12 v and lights as well. A bonus doing this is the headlights for 12 v are cheaper than 6 volt!!
/ Starter not getting full voltage #12
First off, don't convert to a 12V system or use an 8V battery. You should be able to fix this without these.
  • Check the condition of the cables. Are they all heavy gauge cables? (6V systems need heavier cables than 12V systems.) Are they in good condition? Don't forget the ground strap.
  • Check all connections. Are they clean, bright, and tight?
  • Have the battery tested. Does it pass the test?
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
2017 Chevrolet Silverado Pickup Truck (A62613)
2017 Chevrolet...
EZ-Steer Controller and EZ-Steer Motor (A65640)
EZ-Steer...
Air Hose Reel (A65640)
PALLET OF 1 5/8 HYDRAULIC HOSES (A65643)
PALLET OF 1 5/8...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
