Starter going bad in Ranger
   / Starter going bad in Ranger
On a ford the Solonoid is a seperate unit, its sits on the fender? GM's and such have a solonoid on the starter.
This is a factory unit anyway.
   / Starter going bad in Ranger #12
I think my '91 was all in one if I am remembering correctly. I sold it probably 8 years ago.
Thats odd? I have a 90, like i said, 91 is the same truck. My starter is a starter, the solonoid sits on passenger firewall. They do have a little metal cover plate on them if i remember on them that some arm or something i think is under?
   / Starter going bad in Ranger #14
he heard it spin.. so i doubt it is a ford firewall realy issue... the starter motor is getting power.. the bendix is not throwing out. it's likely a mechanical issue .. though could be a small electrical problem in the solenoid section..
   / Starter going bad in Ranger #15
many people confuse or interchangeably use the term relay and solenoid..
the firewall device is a relay.
ok then, i guess the solonoid thing is whats under that tiny cover that throws the bendix out? anyway its not the thing on the fender, starter motor is spinning, last time on a ford 2.3 this happened it was the starter was 99% sure thats the problem but just posted here to confirm.
Since part is so easy to get to and cheap and availible that day im going to pay $35 and get a new lifetime warrenty model and fix it.
   / Starter going bad in Ranger #17
+1, replace the starter. At that mileage/age you're living on borrowed time anyway.
will most likely replace it this weekend, unless i put it off, not cause i think its not the starter just cause.
   / Starter going bad in Ranger #19
let us know what you find.
may even take pics. This is such an easy job i can. Normally im to involved with most stuff to take pics unless im doing it to remember how it goes to geather.
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
2017 SANY SY365C LC EXCAVATOR (A51242)
2017 SANY SY365C...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
John Deere 455G Loader (A48837)
John Deere 455G...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
TMA (A49461)
TMA (A49461)
